The Everything Bike
The Everything Bike
I've been having trouble finding a SS/FG bike that meets my criteria, aside from the Raleigh One Way. I'm primarily looking for a frame with eyelets for fenders and horizontal dropouts so that I can easily change flats. What else is out there? I'd like to keep it under $500 if possible.
The Bianchi San Jose would be a great bike for me aside from its track for ends, plus the fact that they are now discontinued. I'm looking for an everything bike that I can use as my winter trainer and also commuter. I bought a road bike this year and thought I'd stop riding once it got cold outside, but I've absolutely fallen in love with the sport. A steel frame with comfy geometry and the ability to take wider tires are other things I'm looking for in addition to what I mentioned above.
Thanks for your help.
Bikes: '07 Pista, '09 Fantom Cross Uno, '8? Miyata, '67 Stingray, '0? Zoo mod trials, Tallbike, Chopper, '73 Schwinn Collegiate, '67 Triumph Chopper, '69 CB350, '58 BSA Spitfire, '73 CB450
https://surlybikes.com/frames/cross_check_frame/
Here's what I did to mount fenders on my Steamroller (with track ends); I got a set of SKS P45s, and mounted the front one without the included plastic quick release pieces at the bottom of the fender stays. I just used bolts and p-clamps to attach the fender stays to the fork. I saved the plastic pieces for the bottom of the rear fender stays. Mounted those to p-clamps and then attached the fenders to the quick release pieces. Everything was plenty sturdy, and to get the rear wheel out, I just popped the fender out of the quick release pieces to give it enough wiggle room to get the wheel out. Pretty simple and worked great.
Also, the Cross-check will do everything you need it to. Outside your budget though (I assume you meant 500 for a complete bike). However, if you're going to run it single speed, I suppose you could buy the complete and sell the shifters and derailleurs to make a little money back, then just use spacers and a cog on the freehub (no fixed option this way).
I'd like to have a flip flop hub so that I can try both SS and FG. The Cross Check is a good recommendation, but I'd like a complete SS/FG bike instead of going through the buy/sell/build hassle. Main reason I wanted to keep things cheap is so that I can lock it up and beat it up without worrying too much. There don't seem to be too many used Surlys in my area unfortunately.
If you don't mind track ends, the Fantom Cross Uno has rack mounts, cantis, and fits wide tires....
Bikes: 1986 Pinarello Pista
If you can deal with track ends.
https://www.voodoocycles.net/nakisi.htm
And if you must have horizontal dropouts
https://salsacycles.com/bikes/casseroll/
extra bitter
Bikes: Miyata 210, Fuji Royale II, Bridgestone Kabuki, Miyata Ninety
Why not track ends? The Fantom Cross Uno is a good recommendation if you're tied to the $500 budget. But really, when I read the OP, I, just like others, immediately thought of a cross check. It's the do-it-all frame of choice, and includes the flexibility of readily going geared when the time comes. It pretty much exactly matches the criteria you described apart from price point, and you'd probably be well-put to save up for one.
Most bikes that come with track ends do it for style. They are a less good system, a trowback from the olden days. But since people think the want a "track" bike, manufacturers put track ends on the bikes for them. They are useless unless you need them for your time trial bike, or are racing on a velodrome. Horizontal drop outs are the better system, which is why they were the most common, until an even better one came along(vertical drop outs).
Veteran Racer
Bikes: 34 frames + 82 wheels
The problem with most modern frames with horizontal dropouts such as the Surly Crosscheck or Salsa Casseroll is that rear dropout spacing is 130mm or more to permit use of gears, thus limiting the choice of SSFG wheelsets. Although you can often space a ssfg wheel hub from 120mm to 130mm, this puts additional bending stress on the axle that can be an issue if you have heavy loads on the rear of the bike. There are plenty of "track" framesets spaced at 120mm with ample room for fenders and large tires, as well as mounts for fenders and racks. I have a Kilo TT, and the only complaint I have is that it lacks separate fender and rack mounts in the rear.
Bikes: trek t1
Its pretty dumb that the OP doesnt want horizontal drops. Carry a 15mm wrench with you. The one I carry has a tire lever one one side and a 15 on the other. Problem solved
You guys now have me reconsidering track ends, particularly given how much more common they are. From what I've read though, if I install fenders on a bike with track fork ends, then changing a flat out on the road is pretty much impossible unless I bring all my tools and remove the fenders each time I want to take off the wheel, correct?
In choosing your frame, I wouldn't give too much priority to horizontal dropouts over track ends. It doesn't really make a huge difference if the frame has horizontal dropouts or track ends. You can easily get your wheel out with either, unless you chain is too short (trackend problem) or if your tire is too big (horizontal dropout problem). Fenders aren't a problem with track ends if you set the fender up properly. Set the fender up so there is enough clearance in the back to pull out the wheel. I've never had a problem fixing a flat with track ends and fenders. If the fender is set too close, you should be able to get the wheel back on by reinstalling it before you reinflate the tire. Most fenders are pretty flexy anyway, especially the plastic ones (e.g. Planet Bike), so no matter how much clearance you really have, its still possible to get the wheel off and on.
Bikes: trek t1
It will make finding the perfect bike that much easier.
It really depends on how tightly the fender "hugs" the tire at the furthest point back. Yes it will probably be more of a hassle. But having all the air out of the tire, it might be a tight squeeze, or else you will have to partly remove the fender.
Bikes: trek t1
In choosing your frame, I wouldn't give too much priority to horizontal dropouts. It doesn't really make a huge difference if the frame has horizontal dropouts or track ends. You can easily get your wheel out with either, unless you chain is too short (trackend problem) or if your tire is too bike (horizontal dropout problem). Fenders aren't a problem with track ends if you set the fender up properly, with enough clearance in the back to pull out the tires. How often you do need to remove your wheel from the frame anyway?
Nü-Fred
Bikes: Torelli Tipo Uno (stolen), Peugeot Nice, Mercier Kilo TT
unless u have non-full fenders, clip ons, or those easily removed ones like planet bike speed ez
If you need removable fenders, get the PB clipons...they are way better than the speedEZ fenders. Of course the better option would be any full fender that is actually bolted on.
Your post indicates you didn't read carefully and/or are confusing terminology. Also your suggestion to carry around a 15mm wrench is irrelevant to the issue. It makes no difference if the dropouts are horizontal or trackends. You still have to carry around a 15mm wrench if your wheel is bolted on.
OP, I think the Redline 925 is the kind of bike you're looking for: super commuter-friendly singlespeed.
1) Has flip-flop hub and comes with both singlespeed and fixed cogs (unlike bikesdirect, which usually only comes with one)
2) Comes with fenders (planetbike) and a chainguard
3) Has wide tire clearance (28mm stock)
4) Has eyelets for mounting racks and stuff
5) steel frame, relaxed-ish geo (sloping top tube! *gasp*)
I own the '09 version and got it used for ~$300, but the MSRP is either $500 or $600, if you go looking for a new one.
No, you do not need to remove the fenders to take off the back tire.
Hope that helps!
Hope that helps!
