Serious tubeless leak. Why?
Jubalayo Unogwaja!
I replace my Conti 2.6 tubeless tires with Conti 2.1's. My front wheel would then always deflate every 2-3 days or so. I removed the tire and checked the rim but I can find no evidence of rim damage or any sign of damage to the tire. So I switched back to the original which I'd been using for 2 years. Tonight, barely 40 minutes after pumping it up to 50psi, it was flat! Two tires with the same problem? Unlikely perhaps. All I can think of is that the value is at fault and I'm willing to replace it.
Do you think it is likely the cause of my trouble?
If so, can I replace the valve and is there a particular size I need to ask for or is one-size-fits-all? My rims are Mavic 3.1 UST tubeless by the way. Is it possible to overhaul the valve or reseat it, and if so, would I need to use any form of sealent?
Thanks.
Thanks.
The Red Lantern
Could be the valve, could be the tire not seating well. If it goes down in fourty minutes, you should be able to find the source of the leak with a handy tub of water.
Are you a registered member? Why not? click here to register. Its free, and only takes 27 seconds!
Help out the forums, abide by our community guidelines.
I am in the woods and I have gone crazy.
Jubalayo Unogwaja!
It was the valve. I got a replacement from the lbs and since then I've not had a deflation on the front wheel in 2 days so it looks ok now. I looked at the old valve and the rubber seal that fits on the inside of the rim was (a) a bit crusty with dirt, and (b) it seemed to have hardened a bit. Something to keep in mind if you use tubeless rims.
