Pressed in bottom bracket bearings
Quoted: 17 Post(s)
Liked 41 Times
I just thought I'd check before prying these pressed in bearings out of an old Cannondale bottom bracket cup.
(I can't imagine why they did this - I've replaced tons of separate bearing retainers, but never one pressed-in.)
So - Any problem with just prying these out and replacing with loose 1/4" balls?
- Auchen
- Auchen
nope, no problem with just prying out that retainer ring. i had the same bottom bracket (on a cannondale!) and i just tossed the pressed-in retainers after servicing the BB.
take a picture of the other side of that retainer will you? It'd be interesting how they made a retainer to hold 11 balls. The fingers must really be narrow.
I suspect that the "retainer" is also part of a dust and moisture shielding system. We're used to the usual plastic or rubber seals but there was a method called "labyrinth sealing" in the old days where they used back and forth direction changes in the path for any dust or moisture to enter the bearing. The advantage to this style being that since there was no actual contact within the seal area there is no drag at all. This may be part of a similar idea depending on what the rest of the parts look like.
not without first prying out that ring.
I think the ring may be a seating-surface for the plastic accordion-type shield that prevents dirt & water from entering from the seat and downtubes. It can also serve as a production-aid in that it allows people to assemble the bike faster without worrying about 11 loose-bearings falling out and running all across the floor.
I ran into this pulling a BB from a Specialized Hard Rock the other day. I just levered the pressed in side out and popped it back in during re-assembly.
I'm still riding my 1980's C-record BB with the spirals in the cups. Got over 50k-miles on it. Just overall it once a year and that's about it.
Quoted: 17 Post(s)
Liked 41 Times
Southpaw and Danno pretty much had it right - except there was no accordion seal on this particular bike, and there was a little hard black plastic ring, but since this ring shares the same inner diameter as the cup, it was obviously intended to keep the grease inside inside, rather than contaminants outside out.
This would make a lot of sense if you has a bin full of pregreased cups ready to pop into frames on an assembly line.
- I'll just put new balls into it and I'll be all set!
Thanks all.
Thanks all.
- Auchen
- Auchen
philie
Classic & Vintage
10
08-08-15 07:50 AM
