Does front axle size matter?
Bikes: 1977 Raleigh Record, 1987 Schwinn Prelude, 1971 Raleigh Record, 1988 Schwinn Traveler, 1967 (?) Carlton Super Course, 1959 Huffy Sportsman 3 speed, 1972 Raleigh Super Course, yet another 70-something Raleigh Record
Quoted: 50 Post(s)
Liked 18 Times
My Robin Hood frame has become a sort of scavenger hunt. I've come up with a couple of possible front hubs to fit the 91mm fork spacing, but both use 5/16" axle. The drop outs have a sort of keyhole end, and the hole looks to accomodate a 3/8" axle, although I haven't tried to fit an actual hub in there with that size axle. Is the 5/16" okay -- it will pass pretty easily through the bottom of the keyhole.
Location: Rhode Island (an obscure suburb of Connecticut)
Bikes: one of each
Quoted: 8 Post(s)
Liked 12 Times
How heavy are you?
Lots of late 70s bikes, Schwinns in particular, had a little axle in a big hole and a washer with a lip that filled the gap. I think it was a safety feature or something. My LBS had those in stock, they'd make it fit right.
Count Orlok Member
https://www.sheldonbrown.com/english-3.html#fronthub
You may need to file to get a standard front hub to work.
Quoted: 50 Post(s)
Liked 18 Times
Thanks for your replies. I guess I weigh about 180 -- hope that's not too much for a 5/16" axle. I've looked at the reference to Mr. Brown's site, and I guess that's something like what's called for. I'd like to at least see an example of those nuts with the shoulder that goes into the hole. Maybe I can find some on ebay, or something.
Count Orlok Member
My advice would be to find a Raleigh front wheel at a bike recycler/used shop, and just use that.
Quoted: 50 Post(s)
Liked 18 Times
Thanks for the illustration, gna, I guess I thought the lip or "spigot" would be on the outside nut. I would really prefer to find an intact Raleigh front wheel, but I don't think they're very common around here. There are a couple of places I could check. Maybe just keep watching ebay.
Passista
Bikes: 1998 Pinarello Asolo, 1992 KHS Montaņa pro, 1980 Raleigh DL-1, IGH Hybrid, IGH Utility
Quoted: 866 Post(s)
Liked 721 Times
I use a simple solution - a pair of long nuts machined in a lathe to form the shoulder.
Count Orlok Member
Your Robin Hood--do you need the whole front wheel, or just the axle and cones?
Quoted: 50 Post(s)
Liked 18 Times
The idea of machining a pair of nuts makes a lot of sense -- couldn't do it myself, though. Might not be too expensive. I work with some machinists who could no doubt do it. And I could use one of these hubs. I also thought about making spacers from tubing to just fill the gap between the hole and the axle -- looks like 10mm stainless might work. Not sure where to find that either. Gna -- hey, I need both wheels, and quite a bit of other stuff. I just bought this frame and fork on ebay. It had a headset and a pair of (I think) usable bb cups. Didn't have a bb lockring, so I had to buy another used bb to get that. Certainly not a cost effective way to get a bike. I'd just been reading the English 3 speed thread a bunch, and somehow ended up bidding on a frame. If I could find reasonably priced Raleigh wheels, with 91mm front and 111mm or so rear O.L.D's I'd definitely consider that. This will probably be the most expensive $75 bicycle around, it it ever gets all its parts.
Count Orlok Member
Do you have any bike coops, recyclers, or used shops in your area? They may have Raleigh wheels available for a decent price.
Quoted: 50 Post(s)
Liked 18 Times
There's a guy who has a pretty good mostly used shop. I went by there today. He said his mechanic was not there and to come back and bring the fork when he was there. He also mentioned washers that would adapt a hub to the hole size. He didn't say anything in response to my request about a Raleigh wheel. I'll probably try to go by with the fork and a hub next off day I get. There's also a new coop that started about the first of the year. Doubt they would have anything like that, but it might be a good excuse for a visit.
