Loose Headset and Loctite 660
Quoted: 9 Post(s)
I've read short comments of success with Loctite 660 on securing loose headset lower cups. I would like to hear a few more details from those who have used it. Was special preparation required? Anyone removed a cup after bonding with the product?
Quoted: 9 Post(s)
The bottom of the head tube is 30mm wide and 29.8mm deep, clean bare metal. The cup is 30mm OD all around the neck, but it fits easily with just a slight push no twist. I don't have another headset to compare with.
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
What type of headset was that frame designed for? 1" ISO? JIS? Other? What is the headset?
Quoted: 9 Post(s)
Want to send me a new cup to try?
Yes, I'm measuring at multiple points.
It's one inch threaded, the frame is a US made Schwinn, Tange Falcon FL-500 headset.
The headset was becoming loose after each ride and when I pulled it apart the upper bearing cage was missing a ball, but no scoring on either race. I assume the loose feeling was the cup rocking.
If the headset has no play before the ride and gets loose during, it's not necessarily the lower-cup that's loose. If the locknut isn't tightly pinching the upper adjustable cup, it can come loose during the ride. That could be the cause of looseness as well.
slopvehicle
Bicycle Mechanics
6
06-17-13 08:42 AM
