Shift cable to front DR suddenly very loose
Faster but still slow
Bikes: Trek 830 circa 1993 and a Fuji WSD Finest 1.0 2006
On a 21 mile bike ride yesterday, my front DR suddenly stopped working. It was dark so I couldn't tell what happened and kept on riding the remaining 11 miles.
Once I got it home and took a look at it in the light, it was apparent that the shift cable was very slack. I checked it from the brifter to the DR and it appears to be intact and attached at both ends. I pulled on it from either direction and it doesn't seem to be broken.
I can't figure out what happened. Any ideas?
check guide under BB it may be cracked or FD slipped down check bolts.
Look good they crack along the cable line of path so remove and look if needed.
It may not be fancy but it gets me were I need to go.
https://www.jtgraphics.net/cyclist_bicycles.htm
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Or the cable slipped through the clamp on the derailleur. It might not have been quite tight enough.
Quoted: 5774 Post(s)
Liked 2,571 Times
Also double check that the head hasn't pulled out of the lever by pulling it away from the frame and shifting against hand tension, the cable must move cleanly as you move the lever. If it does, the problem is downstream, most likely a loose FD pinch bolt. (you'll see marks on the wire where it slipped)
FB
Chain-L site
FB
Chain-L site
slowandsteady, Might be unlikely, but the cable housing may've become reseated.?
Brad
Brad
lineinthewater
Bicycle Mechanics
13
02-01-13 09:51 AM
christofoo
Bicycle Mechanics
3
06-10-12 09:25 PM
