Cottered TA crankset question
PanGalacticGargleBlaster
Bikes: Upright and Recumbent....too many to list, mostly Vintage.
Quoted: 19 Post(s)
Liked 5 Times
Does a Cottered TA crankset use the same size BB spindle as a cottered Nervar Crankset?
The Spindle in question is on my '72 Raleigh Super Course, I'm considering a Cottered TA crankset. Because I think it looks awesomer than the square taper ones.
The fact that it won't need the stupid special size puller is kinda cool too.
--Don't Panic.
--Don't Panic.
Quoted: 3808 Post(s)
Liked 6,678 Times
I don't think I've ever seen a cottered TA crankset, only Stronglight. Do you have a pic?
Neal
Neal
Location: Rhode Island (an obscure suburb of Connecticut)
Bikes: one of each
Quoted: 8 Post(s)
Liked 12 Times
Isn't there a guy with a website that covers TA really in depth?
The only "cottered: TA I can find any reference to requires a TA BB;
https://www.classiclightweights.co.uk...anks-comp.html
Quoted: 19 Post(s)
Liked 5 Times
I didn't look close enough. Its Nervar with TA rings. Sorry!
--Don't Panic.
--Don't Panic.
Bikes: one of each
Quoted: 8 Post(s)
Liked 12 Times
I have seen two sizes of Nervars. I think it's 5/8" for English and 15mm for French bikes or something like that. I think the Japanese use the same size as the French but they tend to be the cheap kind.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
^Would you believe I had a pair of those, which I gave away to a guy who worked at the lbs about fifteen years ago. What was I thinking.
Old Skeptic
Bikes: 19 road bikes & 1 Track bike
Quoted: 5 Post(s)
Liked 6 Times
Here are some of the rather confusing variables available on old Nervar crank arms which you should also be concerned with.
This is a detail of a 1974 catalog page which was scanned by enthusiast Robert S Broderick. By this point in time, cottered steel cranks were really on their way out in favor of a growing number of inexpensive alloy cotterless cranks. But, Nervar was still producing a wide variety of cranksets in their earlier patterns. With the variations shown in the image below, you could find a very inexpensive replacement crankset to match any of your existing bottom bracket or pedal thread needs. - But, that was then...
Best to accurately measure the diameter of the end of a BB axle. A 5/8" (British standard) axle = 15.88 mm. It will fit into a French diameter opening... but just a bit loosely. A 16 mm (French) axle will not fit into a British crank opening. Also, proper British dimensioned cotter pin [3/8"= 9.5 mm] will not fit into the smaller bore of a French crank arm. To be honest, I've never tested a mis-matched fit, but you might have an issue when combining the two sizes... the tapers may be a bit off and so with such a combination the cotter pin could prove too loose a fit to anchor the smaller axle properly... But, maybe it's no big deal at all.
In any case, Good Luck! Cottered axles are becoming very hard to find - just in a correct required length!
Liked 6,678 Times
No one cares
that's what she said?
I prefer emails to private messages - holiday76@gmail.com
Jack Taylor Super Tourer Tandem (FOR SALE), Jack Taylor Tour of Britain, Px-10, Carlton Flyer, Fuji The Finest, Salsa Fargo, Santa Cruz Tallboy, Carver All-Road .
arthursday
Singlespeed & Fixed Gear
6
12-20-09 10:31 AM
