any help ,somebody who knows
Location: vilage somewhere to peloponesse inGreece amagik country that many would like to try,tried to steel from greek people
Bikes: vortex(city trouble)
help
Hello! I want just learn a tecknikal information,for a german bicycle:Vortex with 28''wheels and custom handlebar Basically,I want to learn about CARTRIDGE SYSTEM (based at the front steering?) HOW IT WORKS..can you help me ,you see the problem is that when I use brake suddenly(a little not to much)I feel a slight gap noise inside the throat(front steering),,,though thefront steering when I moove the front system front-back with thebicykle stable doesn'nt seem to be loosen...
my email is stasolaris@yahoo.gr
I'll appreciate any help
17yrold in 64yrold body
It sounds like your headset may need to be adjusted. Hold the front brake lever tightly, and rock the front back and forth as much as it will go. If you get movement in the headset (the bearings that hold the steer tube in place), it needs to be adjusted. If you do not have the right tools, it may be less expensive to have a shop do it. If you want to try it yourself, loosen the lock nut (the top nut), and adjust the second nut for no slack (movement as described above), but not so much that it binds. Then, while holding this adjustment, tighten the locknut. It might take a couple tries, as the adjustment sometimes changes when the locknut is tightened. Good luck.
As you were asked the last time you posted this, supply pictures and we will be glad to help.
Liked 7 Times
We really need to know if the bicycle has a threaded (quill) type stem and headset or a threadless stem headset.
You should be able to find instructions for adjusting either type at www.parktool.com or www.sheldonbrown.com
Quoted: 2026 Post(s)
Liked 1,096 Times
Uh, asking one time should be enough.
Bikaholic
Bikes: Trek Fuel 90, Giant OCR, Rans Screamer Tandem
If you can post pictures of your bike or search for pictures on the internet of another bike that looks exactly the same as yours, we might be able to offer some assistance.
Brennan_F
Bicycle Mechanics
10
02-22-12 06:44 PM
