Conversion to OS handlebars
Hi,
I am currently running a 26 mm handlebar, with a conversion adapter to go from a quill-type stem to a threadless stem.
I would like to upgrade the bars to a 31.8 mm set. Other than the bar and stem, do I need anything else? My brifters are 2004 vintage Campy Mirage - do I need new clamps to accommodate the fatter bars?
Thanks!
Thanks!
The OS center clamp area tapers down well before the brake lever band .
outside of the center its standard diameter..
But Why do you feel compelled to .. fix that which is not broken?
are you bending handlebars with your massive arm power?
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
Not unusual, since some makers only offer their bars in 31.8mm and many others are moving away from 26mm entirely. FSA and easton comes to mind.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
But if the faceplate in the stem is removable .. that makes any bend work.
people don't need to insert handlebars thru un open able stem /bar clamps any more.
Or those that do, Nitto Rivendale C&V types, wouldnt buy them anyway.
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
@ the OP. If you are looking for additional stiffness then you aren't going ot find it. The quill to threadless adapter will still be the weak link in the chain I'm afraid. If not then disregard.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Liked 5 Times
no, I'm talking about the preference in bends. Someone might like FSA compact, while another would like a cinelli criterium. You can only get FSA compact bars in the 31.8mm diameter clamp. It's a contact point, just like a saddle, and it's absolutely user preference on like or dislike.
Quoted: 2026 Post(s)
Liked 1,095 Times
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 25 Times
+1. The availability of the FSA compact bend which allows me to have the top of the reach level and the brifter hoods a straight extension of them while still having the drops almost level is what lead me to convert to 31.8 bars across the line. "Improved stiffness" had nothing to do with it.
i_am_you
Bicycle Mechanics
16
10-05-13 09:32 AM
