Good thing I run full fenders
Old 12-15-10, 11:23 AM
Portland Fred
banerjek's Avatar
Bikes: Custom Winter, Challenge Seiran SL, Fuji Team Pro, Cattrike Road/Velokit, РOS hybrid
Quoted: 232 Post(s)
Liked 53 Times in 35 Posts
Wouldn't want to get any crud on my bike. This is just from the ride in this morning...
banerjek is offline
Old 12-15-10, 12:04 PM
Kid A
TurbineBlade's Avatar
Liked 5 Times in 5 Posts
Your chain will love all that grit .
I love my full fenders + the "draggin the ground" mud flaps I attached myself. Wouldn't ride without them at this point.
TurbineBlade is offline
Old 12-15-10, 01:36 PM
Stealing Spokes since 82'
Fizzaly's Avatar
Bikes: The always reliable kuwie
Crud like that is why i stopped mounting my pumps on the underside
Fizzaly is offline
Old 12-15-10, 02:48 PM
Portland Fred
banerjek's Avatar
Quoted: 232 Post(s)
Both bottle bosses are taken. I now have a small plastic bag over the head of the pump. I learned the hard way that if you let grit in there, it destroys the rings rendering the pump useless at some critical time. What's unbelievable is that this is supposedly clean highway. This is what one of my bottles looked like the other day after just over an hour of riding. Remember, this is *with* full fenders. Friggin' grit thrown down by DOT for traction....
banerjek is offline
Old 12-15-10, 02:57 PM
groovestew's Avatar
Quoted: 60 Post(s)
Liked 43 Times in 33 Posts
Any pump mount I've seen mounts under the bottle cage, so you can have the pump and bottle cage on the same bosses. Like this:
Anyway, I guess that's off topic. I've posted this picture already in a couple of other threads, but here's my cassette after a 15 km ride in snow and slush, and this is on a bike with full fenders too:
groovestew is offline
Old 12-15-10, 03:32 PM
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times in 169 Posts
If you do not have a wide soft mud flat that almost (or does) hit the ground, fenders don't keep the drive train clean. It's all about the mud flap. The closer it gets to the ground the better, to do that one needs a soft flap that will go up over something. Most of the goop comes from the bottom of the front wheel.
I've made a lot of mud flaps for my bikes and others. A wide MTB tube cut open and then glued folded back onto itself is easy, superglue works fine.. NO need the drill holes in fenders either, just crimp a piece of stiff wire around the flap and the fender will stay, and is easy to replace. A soft flap will even go up over snow.
2manybikes is offline
Old 12-15-10, 03:36 PM
mustachiod's Avatar
^ going to try this, thanks
mustachiod is offline
Old 12-15-10, 04:04 PM
Portland Fred
banerjek's Avatar
Quoted: 232 Post(s)
I've had pump mounts that did that, but the current Road Morph G that I have now does not. In any case, better a pump than a water bottle or battery.
Correct.
My fenders came with flaps, but I removed them because my sense of aesthetics and my aero weenie side were offended. Also, I like to run my fenders really tight -- there is neither room for the clip that holds the rear fender up nor the flaps.
banerjek is offline
Bikes: 2 many
Be careful rolling the bike up over a couple of steps like the entrance to the house, it's easy to step on the mudflap and trip yourself.
Old 12-15-10, 04:11 PM
Bikes: 2 many
Correct.
You just need more bikes, my weigh weenie/aero bikes don't have fenders.
Not sure I understand how tight fenders won't hold flaps on the outside of the fender and just the thickness of a coat hanger wire crimped tightly to the inside of the fender and following the curve of the fender about 1/4" in from the outside edge. Too tight to allow the thickness of a wire in there?
Old 12-15-10, 04:46 PM
Portland Fred
banerjek's Avatar
Quoted: 232 Post(s)
I do have 5 bikes. But I like them all to be fast. I used to use a touring rig for commuting, but what I really wanted was a racer that would take a rack and a lot of abuse. So I had this one built specifically for the purpose.
Correct. I run the clearances so tight that if the ground is damp rather than wet and I go through dirt/sand, it drags. It is less than the thickness of a wire, I can only mount 700/23, and not necessarily any brand. But that is by design.
banerjek is offline
Old 12-15-10, 05:45 PM
Fizzaly's Avatar
Sorry i didnt see the bag but i do now, i still to this day when i go on tours i put a condom over the top of my pump. Several times i ended up with my bike looking like yours and of course got a flat, did patch go to pump it up and....nothing. Im having the same problem not as bad as you though with all the sand on the roads, its been raining in boise for the last week i haven't even bothered lubing the chain.
Fizzaly is offline
Old 12-15-10, 11:14 PM
Quoted: 509 Post(s)
Liked 9 Times in 8 Posts
Where I live, the city and county have some very special grit. It is large enough and sharp enough to cut through Schwalbe Marathons like butter. It contains pieces that are shaped like goatheads, only made out of hardened, cooked tar or basalt. It really sucks that they put material down to keep the poor drunk carcissists on the road that destroys bike tires (and is obviously great for drive trains), all for the six or seven mornings per year that have even the slightest chance of ice formation. I guess it is unreasonable to expect that motorists can slow down on the rare occasions that ice may form on the roadway.
B. Carfree is offline
Old 12-16-10, 03:42 AM
Here are my awesome home-made fenders. I needed these before I could find anything that would be long and wide enough to fit my 29'ers.
DJConspicious is offline
Old 12-16-10, 04:37 AM
imi
aka Timi
imi's Avatar
Bikes: Bianchi Lupo (touring) Bianchi Volpe (commuter), Miyata On Off Road Runner
Quoted: 160 Post(s)
Liked 130 Times in 99 Posts
... i put a condom over the top of my pump.
Great tip! Thanks!
imi is offline
Old 12-16-10, 06:45 AM
slims_s's Avatar
Here: https://www.roadcycler.com/2008/02/to...orph-g-review/ the guy said that he's using a "Hurricane ATB Extra Mini Pump Mount" ( https://www.performancebike.com/bikes..._1031038_-1___ ) on the side of a bottle cage. Only $1.49
slims_s is offline
Old 12-16-10, 09:22 AM
Bikes: 2 many
You still need 10 more bikes.
Is that a custom made bike? Do you have a full bike photo?
Old 12-16-10, 03:32 PM
Maxxxie's Avatar
Bikes: Cannondale Synapse 4 Carbon Feminine
W00t! Thanks for that. I've got one of the Topeak Road Morph pumps and I've had to mount it on my bike's rack so that I can have two water bottle cages. I'm going to get me one of those Hurricane mounts. Thanks mate!
Max
Maxxxie is offline
Robert P
General Cycling Discussion
64
04-01-17 07:45 AM
mattyknacks
Commuting
73
09-02-13 12:38 PM
Capecodder
Classic & Vintage
19
10-31-10 03:47 PM
khatfull
Classic & Vintage
20
09-21-10 08:12 PM
mkeller234
Classic & Vintage
20
03-05-10 01:51 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
