13.2 v niterider battery suggestion?
much appreciate battery advice -- my old classic twin beam niterider 13.2 v battery is dying, and niterider says it doesn't make that battery in a water bottle anymore. i think it's a nicad. does anyone have suggestions on getting a replacement battery that would fit in a water bottle, and how to seal it? thanks a lot, jeff
https://bicycletouringoncarfreepaths.org/
get 11 solder terminal rechargeable 1.2v batterys, put them in series, that is 13,2v.
I have some of their Ni Cad water bottle batteries, they poured canning wax in
around the completed battery bundle..
C sized cells may fit 11 and have a decent amp Hr capacity.
Bikes: Cannondale T700s and a few others
Rebuilt a bottle battery with the C's for $30. If you have a Battery+ most of them can rebuild a battery IF it is potted in a way they can get it apart. The one I rebuilt had some expanding foam it was potted in and wasn't much trouble to get it apart.
Canning wax is going to be a little more tricky. It melts about 125-130f you could set it in a double boiler that is about 150f and melt it and pour it out. I wouldn't get it any hotter then that.
You can go down to wally world and buy the rechargable c's and that may be the cheaper option. Get the highest amp hour "Ah" rating they have. Then solder them together in the same way as the ones yoou tak out.
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
Batteries Plus
So far they have rebuilt 6 different types of battery packs for me and they all work great.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
One of those non water bottle boxes that are made to put tools and cellphones
in waterbottle cages may be easier to work around , than using an actual bottle ...
bobotech
Bicycle Mechanics
24
06-06-13 02:05 AM
Richard Cranium
21
03-28-11 02:26 PM
