cassette for racing (compact crank)
Hello,
I plan on racing for the first time this year. So far I've only raced in tri's. Anyway...in addition to my triathlon races, I'd like to do one crit and one road race (hilly). I'm running a compact on my roadbike. Do I have to switch to a standard to keep up? Or are racers able to get by with a compact (I don't expect to win). Also...right now I'm running a 11-23 cassette. It has worked pretty good. I'm wondering though if a 11-25 or 11-27 might be better for hills? Can I just use a compact(50/34) crank plus a 11-27 cassette for just about any race I plan on doing? Or is that an awful compromise?
Thanks!
Thanks!
Liked 6 Times
Locally, we have a couple race courses where a 50 x 11 is not high enough to stay in contention. One is an auto racetrack that often finishes down a dragstrip with a 25mph+ tailwind assist. Another is a hilly course where you can crack 50mph+ on an extended descent if you can deliver some power at those speeds. But if you're a first-time racer, start with your compact and see how it goes. Just don't give up your 11 in back.
As for cassettes, can you try out your existing setup on the racecourse? Personally, I like the 11-23 because it includes every cog from 11 to 17 before starting into multi-tooth jumps, so I can stay near my preferred cadence. But then again, you don't want to be halfway through a race and find that you've overextended yourself and need a lower gear to keep your head above water, either.
If you do get a wider-range cassette, plan to get a new chain for it. You'll need more length to handle a 27 or 28 for sure, and it's best to keep your chain and cassette at similar levels of wear.
Glimmers of form
Bikes: Cannondale SystemSix 3, Specialized Stumpjumper M4 Comp
I went from 3->2 and 2->1 using a 50-34 with either a 11-23 or 11-26 cassette. You should be fine in the 5's.
impressive member
Bikes: c'dale supersix, jamis trilogy, spec. tricross
if you really wanna cover your bases, i had good results as a 4 with a compact crank with a 52 and a 36, and a 11-23 and an 11-26 for steeper, longer efforts.
BALM Co.
Bikes: 2010 Aerocat rR350, 2010 Aerocat R750, 2014 Salsa El Mariachi, 1986 Bianchi Trofeo, 2013 Trek Ion Pro CX
Quoted: 140 Post(s)
Liked 327 Times
I've used a 50x34, 11-23 for all my racing Cat 5 through Cat 2. I've been undergeared in 2 races. Big tailwind in one, big downhill in the other.
Bikes: 1997 Trek 520
Should be noted that the 50x11 is actually a bigger gear then the 53x12 that a lot of people run.
I use a 50/34 and 12-27 for everything except the Everest Challenge where I use a 12-30.
I've not had high enough gears once, in a race that featured a long slightly downhill section with a really stiff tail wind. Normally on descents I have to draft larger riders anyhow so not being able to pedal isn't a problem. But in this race the tailwind negated most of the effects of the draft. I can spin the 50x12 to 40 mph to get on someone's wheel but I can't do it for 20 minutes.
I'll bring an 11t cog next time.
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Depends on the terrain. I use a 53-39, with a 12-25. I would only use an 11 a few times a year. I'd rather stick with the 12 and have 1 more cog in the middle that would get used all the time.
impressive member
i think so, yeah.
i made the switch earlier in the season but i dont remember when.
as side note, i ended up with a full sized crank on my new bike this year and took it out for a group ride on saturday and realized, within an hour, without counting or checking, that the cassette was a a 12 instead of an 11. the 12 was a noticeable limter, even with the 53 vs the 52 i've been riding for a year. only on downhills obviously, but it was still annoying.
Quoted: 43 Post(s)
Last year was my first year racing and used a compact crank with an 11-26 rear cassette. I felt like I did fine with this setup. However, I will say that I changed to a standard crank and can tell a big difference (I like it much better and fell like I can maintain a cruising speed in the pack easier). I don't know how much of this is in my head vs. actual difference. For your first year, you'll be fine...if you want to get more competitive in the following years, you may want to consider making the switch.
fair weather cyclist
1I use a 34-50 with 13-26 and never have been dropped do to spinning out.
Big downhill can be tough... usually end up tucking and coasting. 50x13 @ 120 rpm is 36mph on a flat .
Gunner.
Bikes: Giant TCR, Spooky Skeletor, Pivot Mach 6
Quoted: 9 Post(s)
Liked 9 Times
I race with a compact and it's not the crankset that makes me slow. I use an 11/27 casette.
With an 11-23 cassette on a 50/34 compact crank, you are basically running similar to a 53/39 with a 12-25 cassette. The only problem with compact cranksets is they drop chains more easily because of the smaller diameter small ring. If you are into spending money, you'll be fine on a 53/39 and it'll be a bit more reliable, but you are probably just as well off keeping what you have and racing for a while.
Cat 2 Track, Cat 3 Road.
"If you’re new enough [to racing] that you would ask such question, then i would hazard a guess that if you just made up a workout that sounded hard to do, and did it, you’d probably get faster." --the tiniest sprinter
Bikes: '07 Specialized S-Works Tarmac SL, DuraAce, Easton EA90 Aero Wheels (or MAVIC Carbone SLs)
If you find you need gears anywhere, it'll be a bigger cog in the back for uber steep climbs (climbs = longer than hills). That's a simple and relatively cheap cassette swap compared to new chainrings.
Once you get used to it, it's not a problem. It's a user cognizance issue. You just have to shift either earlier or later on the hills than what you're used to with bigger rings. If the OP has always ridden compact, he'll be used to the shifting.
baiskeli
Road Cycling
47
11-29-12 11:41 AM
AK404
Road Cycling
39
11-05-12 10:52 PM
