Want to get back into cycling, what's the best way please?
Hi I have just joined, and I live in the UK. I haven't ridden my bike for a while and would like to get back into cycling, after being told by my nurse I'm slightly overweight. I have a curvature of the spin, and I am worried that my back will give me pain if I try and get back into it again and put me off. What's the best way of doing it please?
Heretic
Bikes: Specialized Sirrus, Giant OCR3, Giant CRS3
Quoted: 2827 Post(s)
Liked 561 Times
I take it "curvature of the spin" was just a freudian slip.
There's only one way to find out if you are going to have pain and that's to start with something that will give you an upright stance like a straight handlebar hybrid. Take it easy to start and don't over do it. A combination of diet and exercise (walking also) will bring down your weight over time.
Maybe your nurse can give you some advice and encouragement.
Make sure your saddle and handlebar is set right and just go for it.
Best of luck.
Best of luck.
Apologies, I have dyslexia. I will ask my nurse for advice, have to replace the tyre's first with new one's. Could you please recommend a UK magazine that's for family cycling, not sporty? Many thanks.
Heretic
Liked 561 Times
Hi again,
I used to have a subscription with Cycling Plus magazine which is probably the least sporty but still has quite a bit on road racing etc.
As you can probably tell from the shelves in your newsagent most cycling magazines are aimed towards the club racer and mtb people.
I'd recommend you join the Cyclists Touring Club who despite the name cover all types of leisure cycling and do advocacy work on behalf of UK cyclists. They have a glossy magazine called Cycle that is issued to all members 6 times a year. It's not advertising driven so tends more to cover the genuine needs and interests of ordinary cyclists. I used to be a member of the CTC myself and am seriously thinking of becoming a member again.
https://www.ctc.org.uk/DesktopDefault.aspx?TabID=3327
Quoted: 5 Post(s)
Liked 5 Times
I would start with the question -- What kind of a bike do you currently have?
Given your back condition, is it set up (can it be set up) to give you a comfortable riding position?
Make sure your nurse/doctor knows you're planning on starting cycling, and they approve of it for your particular condition. There's no fooling around with spine!
I would suggest that you go to your local bike store with your bike and ask to be fitted (or maybe call first for appointment). They will be able to see your position, make sure your bike is the right size and fit, and if not, suggest changes. You will probably be charged for this, but it's well worth the money. And get the new tires from them, you can start a very nice relationship with your local bike store, very valuable.
Once you know that your bike fits you, just ride. You may find out that certain things still give you trouble, and maybe more adjustments are needed, that's normal. Take it slow, and ride more as your fitness level increases.
There's lots of great info here, on Bike Forums. Have a look at hybrid forum, general cycling etc. Lots of great advice, and a bit of fun and community as well.
Welcome and congrats on taking up the cycling!
Time for a change.
Liked 5 Times
On your back- Ride the bike gently and see if the back can take the strain. You won't know till you try it but if it is a recent Ailment since you last rode-then it could cause a few problems. I have a back problem and I cannot sit upright on a bike. I ride road with drop bars and a stretched out position. That long stretched position takes the vertical strain off the vertebrae and is comfortable. Even on the MTB I have a longer lower position than I used to have to accomodate the back.
But all of us are different- And hopefully you can still ride your current Dawes "Hybrid"?
Just hope you don't have start thinking about a recumbent--Beards and Potbelly's don't suit all of us
Spike Milligan
Spike Milligan
2 Fat 2 Furious
Bikes: 2009 Specialized Rockhopper Comp Disc, 2009 Specialized Tricross Sport RIP
Your doctor can probably give you better advice than a thousand bulletin boards about whether cycling is likely to cause you problems, simply because s/he will know how it affects you rather than what it might be like as a generic condition. But as others have said, if you avoid cycling positions that are most prone to cause you problems you may be able to enjoy cycling. Being "slightly overweight" isn't a problem - exercise is a great way to fix the weight issue.
Time for a change.
Liked 5 Times
A recumbent is a bike but you more of Lay down on it with your feet being the foremost part of the body. You either like them or you don't but many cyclists that have run into back problems with a "Normal" cycle can ride these successfully.
They are a bit unusual so I am certain you must have seen them about as you will know when you have seen one.
The beard and potbelly is tongue in cheek as they are ridden by allsorts of people.
Spike Milligan
Spike Milligan
Thanks for that. Going to check out a place called https://www.cycleworld.co.uk/ as they are charging 1/2 price on servicing bikes. Are they very good?
Time for a change.
Liked 5 Times
Spike Milligan
Spike Milligan
Bikes: 1997 Gary Fisher Mamba, 1999 Corratec Free Ride FS LX (frame), 2006 Bicycles TXF 900 & a number of various clunkers...
Isn't it a tad bit too late to ask this question after you had bought it?
Now, the best helmet is the one which fits your head best and suits your requirements of comfort and style. Apart from that, the majority of helmets on the market are made good enough in terms of safety and durability, too - keep in mind that regardless of the use, the hat should be replaced after approx. 5 years since the material ages (and throw it immediately in the can after an impact, of course).
Juhan
General Cycling Discussion
45
12-13-22 08:34 PM
folder fanatic
Advocacy & Safety
66
04-01-10 10:06 PM
