Brompton rear brake cable routing: Please check yours and answer below
Bromptonaut
Bikes: 1994 Diamond Back Racing Prevail ti; Miyata 914, Miyata 1000, 2017 Van Nicholas Chinook
Quoted: 23 Post(s)
is the cable on the Brompton you had a chance to inspect going through the designated area of the frame attached to the rear triangle or just next to it?
Thank you.
Thank you.
Feel free to follow me on Instagram
Caltrain Commuter
Bikes: Brompton S-type with S-A 8-speed hub
The square hole is for a pulley block that routes the shift cable on Bromptons with internally-geared hubs. Looks like you have a two-speed, and do not have this pulley block.
The brake cable does not pass through this hole.
Bikes: Brompton T6, Koga Miyata Distance, Airnimal Joey
Bromptonaut
Quoted: 23 Post(s)
Thank you. Case Closed.
