I need some advice of lacing
Old 10-18-04 | 08:29 PM
phantomcow2's Avatar
la vache fantôme
Okay well i have my hubs and rims on order. THe final peice of my first wheel building project is figuring out how i want to lace this. On this site https://www.stormpages.com/spokeanwheel/whl_bldg.htm there are presented some options of how you wish to lace. I am doing both front and rear wheels so suggestions for both would be nice. I suppose i need to say some background here, I ride hardtail, not a really big kid so im under 150lbs. I do most every kind of cycling. 50-60% road and the rest on the trails with the occasional jump (not these 5 foot drops though, 2 is usually the most). 32h and i use disc brakes. Oh i guess it wouldn hurt to say i have a 9 speed cassette ont here too. THa site siad stuff about crows foot and all, has any1 tried that? Okay and one last thing is am i going to need different size spoeks for different lacing patterns?
phantomcow2 is offline
Reply
Old 10-18-04 | 10:17 PM
20 Anniversary
Bikes: Peugeot Hybrid, Minelli Hybrid
He says in his first paragraph - If you are building your first wheel(s), you should start with a conventional pattern. 3 cross, with 2.0/1.8 mm double butted spokes with brass nipples.
AndrewP is offline
Reply
Old 10-18-04 | 10:22 PM
25 Anniversary
Bikes: Lots
If you are using discs, I would ONLY suggest a 3x pattern.
Heck, I ONLY suggest a 3x pattern for any mountain bike.
Radial lacing is too harsh and too fragile.
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, What a Ride!" - unknown
"Your Bike Sucks" - Sky Yaeger
a2psyklnut is offline
Reply
Old 10-19-04 | 07:24 AM
la vache fantôme
I know they siad start with 3 cross. But do i use that for front and rear?
Reply
Old 10-19-04 | 08:15 AM
dirtyscratches's Avatar
20 Anniversary
3 cross front and rear will work fine. You will need different spoke lengths for drive side vs non-drive side. Go to LBS and tell them the hubs, rims, and the lacing pattern you want and ask them to give you spokes. There are calculators on the web, but it's easier to just go to LBS.
dirtyscratches is offline
Reply
Old 10-19-04 | 04:03 PM
Retro Grouch's Avatar
Titanium Club Membership
20 Anniversary
3-cross has been the standard that has passed the test of time. Ask yourself this: Is there a good reason to go with some pattern other than 3-cross?
I've built a lot more than one set of wheels and 3-cross is what I do all of the time unless there is a compelling reason to do otherwise. Sometimes boreing is good.
Retro Grouch is offline
Reply
Old 10-19-04 | 04:10 PM
Hey guys, this is his first wheel building project. Didn't you also read all the cool and odd solutions to a problem when you first faced it? Didn't you also calculate again and again and again on different solutions to find the optimal. Didn't you also find it all very interesting, educating, fun, and that the standard often is standard for a purpose. And ended up doing as everyone else, the standard.
Berodesign is offline
Reply
Old 10-19-04 | 04:24 PM
Good luck with your first wheelbuilding project! I also recommend X3 front and back, because you are using disc brakes. Having the spokes crossed will allow the hub to transmit torque to the rim. So rear wheels on the drive side for every bike need the spokes crossed. Bikes with disc brakes also need crossing spokes on the brake side. One thing I've never seen is a front wheel with X3 on the brake side and radial on the non-brake side. That would be wild, and would probably work, but it would be going against the grain a little bit.
FYI, DT Swiss, the makers of some of the best spokes, have a great online spoke length calculator. Try it! You need to enter the correct hub and rim model. Their list is pretty complete, but not 100%
https://www.dtswiss.com/index.asp?fus...category.bikes
Click on Spoke Calculator.
bubbabear is offline
Reply
Old 10-19-04 | 04:53 PM
la vache fantôme
you know i think im going to bring the stuff ot the lbs and have them tell me becuase it seeems to be thers so many measures you need for these online calculators and im afraid of my measurnment being off. I think i will go for 3x then as it is seems to be what you are all recomending. ANd i believe Sheldon brown has instructions on his site
Reply
Old 10-19-04 | 04:55 PM
la vache fantôme
oh, one more thing. Has anybody tried Vuelta rims? Im seeing these for sale and im just curious about them.
Reply
Old 10-19-04 | 08:45 PM
20 Anniversary
I have Vuelta Airline 3. They 622X19 30 mm deep, made of 6063 T6 alloy. I think they look pretty, but are probably rather heavy. I like them because I weigh 235 lbs and used to be always having to retrue my wheels. In the 2 or 3 years I have been riding on these my wheels have never gone out of true. I have however heard they are poor quality wheels.
AndrewP is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
