Bottom bracket "clicking"??
Old 04-03-02 | 07:04 PM
20 Anniversary
I'm getting a clicking noise from my BB when climbing hills. My bike is 25 years old, however, I have repacked the bearings and am getting very smooth operation with no play when the chain is removed.
I know it's the BB, because even with the chain removed, I can hear a very faint clicking when I turn the crank with my hands, but it gets much louder when climbing.
Any ideas appreciated.
Good Riding!
tallcliff is offline
Reply
Old 04-03-02 | 07:20 PM
mike's Avatar
25 Anniversary
You cleaned and repacked your bearings and you have the cones tightened just right, you say.
If you didn't replace the bearings, you might as well do that too.
Assuming you have done that, check the very obvious;
Any chance the clicking could come from the pedals?
This may be a stupid question, but if you have a kick stand, sometimes it comes loose, and the crank arm hits it.
Finally, look elsewhere on the bike for something that is loose. I once took my BB apart due to a maddening click. I found the problem to be the cable lock swinging and banging against the frame. I could have swore it was coming from the BB, though.
mike is offline
Reply
Old 04-03-02 | 09:09 PM
20 Anniversary
Thanks Mike for your reply. No, I didn't replace the bearings. They looked OK to me, but that's an interesting possibility.
I'll have to check that.
Good Riding!
Reply
Old 04-04-02 | 04:38 AM
chewa's Avatar
The Flying Scot
20 Anniversary
From: North Queensferry Scotland and London (and France)
Bikes: Custom (Colin Laing) 531c fast tourer/audax, 1964 Flying Scot Continental, 1995 Cinelli Supercorsa, Holdsworth Mistral single speed, Dahon Speed 6 (folder), Micmo Sirocco and a few more
Might be the bearing faces are pitted, or pedals, or possibly a slightly loose crank?
plus je vois les hommes, plus j'admire les chiens
1985 Sandy Gilchrist-Colin Laing built 531c Audax/fast tourer.
1964 Flying Scot Continental (531)
1995 Cinelli Supercorsa (Columbus SLX)
1980s Holdsworth Mistral fixed (531)
2005 Dahon Speed 6 (folder)
(YES I LIKE STEEL)
2008 Viking Saratoga tandem
2008 Micmo Sirocco Hybrid (aluminium!)
2012 BTwin Rockrider 8.1
chewa is offline
Reply
Old 04-04-02 | 04:52 AM
Astra's Avatar
20 Anniversary
I'd definitely replace the bearings. Maybe if they're worn, they will be measurably smaller than new ones possibly altering the fit of other BB components causing the clicking. 25 years is a long time to run one set of bearings.
My MTB has a Deore XT headset with 1/4" bearing. I regrease it with Finishline regularly but when I took it offf the bike the other day, the lower set had a matt finish and looked noticeably smaller than the top ones; this was after about three years hard off-roading .
Astra is offline
Reply
Old 04-04-02 | 06:28 AM
20 Anniversary
I'm betting that a chainring bolt is hitting the chainstay
Je vais à vélo, donc je suis!
D*Alex is offline
Reply
Old 04-04-02 | 07:05 AM
Astra's Avatar
20 Anniversary
STEP RIGHT UP LADIES AND GENTLEMEN !!! We're offering 5-2 on worn bearings, even stevens on a loose chainring bolt, 3-1 on the end of the crank hitting the chainstay and a 15-1 on a small pixie sitting in the bottom bracket shell hitting it regularly with a small hammer - PLACE YOUR BETS NOW !!!
Astra is offline
Reply
Old 04-04-02 | 08:20 AM
lotek's Avatar
Titanium Club Membership
20 Anniversary
Bikes: 1 trek, serotta, rih, de Reus, Pogliaghi and finally a Zieleman! and got a DeRosa
I believe its gremlins.
that said, if its a 25 year old bike I'd check
the crank arms. There was some
discussion on Campy only about cracking and failure on older arms.
bearings become somewhat ovoid during use
and will not run really smooth if
repacked and not replaced.
Marty
Sono più lento di quel che sembra.
Odio la gente, tutti.
Want to upgrade your membership? Click Here.
lotek is offline
Reply
Old 04-09-02 | 04:26 AM
20 Anniversary
Thanks for your replies Guys. I did some investigating last evening and have found that the clicking is in the chainrings--even when the bike is stationary, and I apply pressure to the pedal.
I disassembled the entire chainring set, lubed the bolts and retightened, with NO difference. It's almost like the rings are clicking from the flexing they do when under pressure.
I know it could be a cracked frame, but I see no evidence of that. The bike is 25 years old...maybe I'll just "turn the radio up"!
Good Riding!
Reply
Old 04-09-02 | 05:04 AM
roadbuzz's Avatar
Just ride.
25 Anniversary
Did you grease threads, etc., for the BB mounting when you re-installed?
roadbuzz is offline
Reply
Old 04-09-02 | 05:59 PM
fubar5's Avatar
0^0
20 Anniversary
Bikes: Redline Monocog,Surly Crosscheck, Lemond Reno
Well, in your first post it only clicked when you wre going uphill. Based on that I say loose crankset bolt.
Booyah!!
fubar5 is offline
Reply
Old 04-09-02 | 07:51 PM
20 Anniversary
Is your left hand crank clicking on the tab of front der cable?
--walt-- is offline
Reply
Old 04-10-02 | 05:07 AM
20 Anniversary
I did grease the BB thread when I reassembled, BUT, I could only get one side off, and that was the left (non-drive) side. I couldn't figure out if the drive side was threaded or what, but it didn't seem to want to budge.
There's no bolts loose in the crankset and Walt, I'm not sure what you mean in your question.
Thanks Guys!
Reply
Old 04-10-02 | 05:21 AM
20 Anniversary
The reason why it wouldn't budge is because it is left-threaded.
Having heard that admission, I would assume that you probably damaged it attempting to unthread it the wrong direction. Get the proper tool, remove the BB, and replace it. I'll bet that the sound will be gone.
D*Alex is offline
Reply
Old 04-10-02 | 07:24 AM
20 Anniversary
Sorry for not explaining better, sometimes after a front derailleur cable is replaced, the end beyond the pinch bolt ends up bent over just far enough to touch one crank or another when you pedal, it creates a faint but audible click.
Most clicks in cranks and chainrings only happen under load, but you commented you could hear it without a chain on so I was looking for the obscure solution.
--walt-- is offline
Reply
Old 04-13-02 | 06:06 AM
20 Anniversary
I took this clicking cycle to our best diagnostic LBS in the area and they could not tell, from listening to it, why it was clicking either. Of coarse they offered to disassemble everything to help find it, but that's the same thing I'm doing.
I'm going back into the BB, reinstall with new bearings, grease the bracket threads, check for pits everywhere, and see what happens then.
Thanks Guys!
Reply
Old 04-13-02 | 10:47 AM
beowoulfe's Avatar
Honorable Member
20 Anniversary
The last time I had that clicking, it was in my pedals.
beowoulfe is offline
Reply
Old 04-14-02 | 05:34 AM
20 Anniversary
Thanks for your reply Beo, yes I suspected the pedals too and changed them with no difference.
Reply
Old 04-18-02 | 04:39 AM
20 Anniversary
I fixed the clicking noise! The click was coming from the joint of the large chain ring and the crank arm.
I found it by removing my crank-set and installing it on another bike. Sure enough, it was clicking.
The large chain ring and the crank arm are joined together, not by a weld,--they are not one piece--but by some kind of joint. When I ran some penetrating oil in the joint...it quieted down...finally!
Thanks for all your help Guys!
Good Riding!
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
