Tools that you just "Discovered!"
Bikes: something
For me it was using a fourth hand for the first time: Fourth Hand
Anyone else recently discovered a tool that just made their life much simpler?
Liked 6 Times
I used to use my Cal-Van snapring plier a lot in the old days. It was useful for getting quill stems around the corners on drop bars, and installing/removing bar-ends on mountain bikes. Both those scenarios are less frequent, but it's a great tool when the situation arises.
Another good one: large Sterilite under-bed storage bin with wheels. It's a big shallow rectangle and makes a good catch pan when cleaning bikes with a brush and sudsy water.
And another: Quick-Wedge split-tip screw starter, great for wheel building on conventional double-walled rims.
I also like the flex-head long-handle Craftsman ratchets because in 90° mode, they work as speeders if you're not up against too much resistance. The 1/2"-drive model's great for spinning bottom brackets in & out, for example.
Stanley nitrile gloves are also great when working on messy greasy stuff. You can get those at Fred Meyer.
Other nominees: Park Tool's new dummy pedal. Dualco handheld grease gun with long tip. Makita 10.8v cordless drill/driver with a 1/4" square-drive adapter and hex-bit sockets. Li-ion cordless Dremel. Rubber band. Piece of tough nylon twine I found by side of road, that I can hang a bar & stem from while the fork's out.
Bikaholic
Bikes: Trek Fuel 90, Giant OCR, Rans Screamer Tandem
Kool Stop Tire Bead Jack. This really comes in handy on those odd occasions where you have a really tight fitting tire and rim combination. https://www.universalcycles.com/shopp...4&category=199
Quoted: 19 Post(s)
Liked 7 Times
I havent just discovered the Pamir Hypercracker. I wish I could find one though.
It is an essential tool for roadside spoke replacement but totally unavailable.
I have used some of the modern equivalents but they lack leverage and are 2nd rate.
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,923 Times
this 1/2 drive tool I had to borrow from my brother
I knew such tool existed but never dreamed I would need one to work on a bike.
Sugar "Kane" Kowalczyk
Quoted: 1438 Post(s)
Liked 1,092 Times
VIM Tools HBR5 Mini-Ratchet - A compact ratchet with fine ratcheting teeth (52 clicks per revolution) which drives both 1/4 inch square drive sockets and 1/4 hex drive bits. It has a thumb spinner on each end and can be easily used one-handed, including reversing the ratchet. Just the right size for me; gives enough leverage without being too long.
Mad bike riding scientist
Quoted: 6212 Post(s)
Liked 4,210 Times
Other "recent" tools I've found are:
Pedros Vice Whip
Expensive but so much easier than chain whips.
Crown Race remover
Best race removal tool I've ever used.
Chris King External bearing tool
Expensive but not too much worse than the Park wrench and it works better.
Stuart Black
Stuart Black
Quoted: 9 Post(s)
lithium ion 12v/10.8v drill for reflectors. lock ring pliers, roto/swivel ratchets. stem/spacer/handlebar stack holder. made from a piece of steerer tube and an old threadless stem. pop the top cap off the headset and ram the tool down and it pushes the fork out and holds the stem and spacer stack. 29 million ratchets with pre attached bits(hex bits, bb tools, sockets). cheater pipes made from seatposts and pumps. use old grip tape or scrap cut offs for extra grip
Quoted: 118 Post(s)
Liked 50 Times
2 Rafter hooks, 2 ratcheting cargo tie downs, a bungee and an eye plate with 2 redheads. About $30.00 and it all makes a great hanging work stand that easily accommodates recumbents and DF's. Open access to both sides of the bike and no clamping pressure anywhere. All for about $35.00. bk
I like discovering non-bike applications for my bike tools. I have used my pin spanners for somany different things I have lost count. Most recently to fix a leaky faucet. I also recently managed to fix an out-of-plumb hanging closet door with an old hub locknut.
Bikes: '02 Lemond Buenos Aires, '98 Fuji Touring w/ Shimano Nexus premium, '06 Jamis Nova 853 cross frame set up as commuter, '03 Fuji Roubaix Pro 853 back up training bike
Retail merchandising "hang tab" used as brake pad toe-in tool. Light Adhesive on one side so it sticks to the rim, just a scoesh thinner than a credit card, built in hole for hanging, less than a dime a dozen. Ideal for a mechanic who builds lots of bikes.
https://www.southernimperial.com/1-62...bs-p-2677.html
SE Wis
Quoted: 2743 Post(s)
Liked 3,390 Times
One of my favorites is a teenager to run back down in the basement from the garage or vise/versa when I need a different tool I forgot. "Oh, and grab a beer from the fridge for me when you go by too"
Bianchi Goddess
Liked 2,923 Times
great tools. I have a different sort of chain holder/compressor somewhere but when I needed it last week it was AWOL. I seldom need a crown race remover but this one looks real nice does it fit 1"/ 11/8" / and 11/4"??
Chain compressor. Had something similar for ages.
Pedros Vice Whip
Crown Race remover
Pedros Vice Whip
Crown Race remover
Bianchi Goddess
Liked 2,923 Times
never drink with your friends while wrenching. as you can see one had be very careful about which wayt oturn this as I had to go through the BB to access the adjustable cup. so you really have to stop and think about which way you are turning
Liked 4,210 Times
Some "tools" I forgot:
A nickel. Use it for setting the front derailer gap above the crank.
An old plastic bus pass...the ones that San Francisco sells for their buses is ideal...for setting the gap on disc brake pads. Put one on each side between the pads and rotors, then adjust the caliper so that it is parallel to the rotor. Squeeze the brakes a couple of times to align the caliper and then tighten every thing up.
Park master link pliers.
Stuart Black
Stuart Black
newMember
Bikes: 2010 Kona Jake The Snake, 2010 Everti Falcon, 2008 Norco CRD 1, 1984 Bianchi Tipo Corsa,
Home Depot carries Husky tools including various 1/4" ratchet sets, cheap. I have a set with a full range of small hex and screw driver bits, as well as small hex sockets. Cost me $5, love it. Way more convenient than allen keys.
Certified Bike Brat
Quoted: 5 Post(s)
Liked 6 Times
Does this forum count?
This is actually my first experience with a bike forum and I`m finding that there is a lot of expertise available here and in particular from a dozen or so of the people who are posting regurarly.
Old fart
Quoted: 3587 Post(s)
Liked 3,398 Times
Liked 6 Times
I have even had people send me items cost and post free.
Thanks again Hillrider.
