Trimming skewers?
Trimming skewers?
I have some Ti skewers that are too long and stick out beyond the caps. I need to take 8mm off the front and 5mm off the back.
The plan is vice and hacksaw. Any other considerations? Will the threads be OK if I just use the hacksaw?
Thanks.
Thanks.
Liked 6 Times
I suggest threading a nut onto them inboard of where you'll cut. Then cut them, clean up the end with a file, and clamp the nut into the vise enough to ovalize it slightly so it's offering a little resistance as you back the skewer out of it. This should result in a nice lead-in thread.
Typical ti skewers are 5mm x 0.8mm, a common thread for bike parts, so hopefully you've got a couple 5x0.8 nuts laying around.
Quoted: 14 Post(s)
Liked 13 Times
Personally, I'd recommend that you thread some nuts on it, hold the nuts in a vise, and use a cutoff wheel in a Dremel. Then really carefully clean up the threads with a small file and use a wire brush wheel in the Dremel to put the finishing touches on it. But I'd use a threading die to clean up the threads since I have one.
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 145 Post(s)
Liked 35 Times
As Looigi stated, steel QR nut you don't mind wasting inboard. Dremel/RotoZip with cutting wheel....round the end with a small file...remove steel QR nut.
Thread cleaning is not really necessary - however you'll want to find a Sharpie that matches the skewer color and "paint" the end so it doesn't visibly stick out like a sore thumb.
=8-)
=8-)
5000+ wheels built since 1984...
Disclaimer:
1. I do not claim to be an expert in bicycle mechanics despite my experience.
2. I like anyone will comment in other areas.
3. I do not own the preexisting concepts of DISH and ERD.
4. I will provide information as I always have to others that I believe will help them protect themselves from unscrupulous mechanics.
5. My all time favorite book is:
Kahane, Howard. Logic and Contemporary Rhetoric: The Use of Reason in Everyday Life
Disclaimer:
