SE Landing Gear forks question
Liked 5 Times
Hi. Been searching; found nothing. Does anyone here know what size crown race the 1" threaded SE Landing Gear forks take? I need a 26" straight blade/cruiser=style fork in 1" threaded, with a 26.4 crown race.
Thanks for any info,
-rob
-rob
That should be the old school size, The newer ones should fit that bill also.
1984 Cannondale ST
1985 Cannondale SR300
1980 Gary Littlejohn Cruiser
1984 Trek 760
1981 Trek 710
Pics
1984 Cannondale ST
1984 Trek 760
1981 Trek 710
Pics
You can always take it to a shop somewhere and get them to use a Crown race cutter on it if it doesn't fit. I did that to my Landing Gear forks when I had a extra piece of pipe welded into the bottom/inside of the fork and also had the welder weld the top along where the crown race sits. I then ground the extra material down and finished it off with the crown race cutter to use a Stronglight A9 lower headset race/bearing on my Littlejohn. This was after it encountered a tree at high speed, head on, and the headset tube was ovalized (which was also welded up and refaced) and the original fork was mangled beyond repair.
1984 Cannondale ST
1984 Trek 760
1981 Trek 710
Pics
1984 Cannondale ST
1984 Trek 760
1981 Trek 710
Pics
Williamcornock
Bicycle Mechanics
0
03-24-16 09:22 AM
FixMEplease
Singlespeed & Fixed Gear
6
01-07-16 09:22 PM
