Cable end fray treatment?
Old 03-15-11, 06:16 AM
R20, 650B, Touring
BillP's Avatar
Bikes: Oh dear.
Liked 3 Times in 3 Posts
Hiya ,
I used to solder up the ends of cables to stop them fraying, but the new stainless steel stuff doesn't seem to want to take solder. And I think also that modern cables fray more readily?. What y'all doin fer this?
When did the aluminium blind crimps come in? I think they might be post C & V?
What about shrink tube?
Bill P
BillP is offline
Old 03-15-11, 06:30 AM
Old Yeller's Avatar
Bikes: 1987 Trek 1500, 1989 Pinarello Montello, 1998 Trek 7000 MTB
Quoted: 7 Post(s)
Liked 5 Times in 5 Posts
Try a drop of super glue on the stainless instead of solder.
Old Yeller is offline
Old 03-15-11, 06:47 AM
rhm
multimodal commuter
rhm's Avatar
Quoted: 1908 Post(s)
Liked 574 Times in 339 Posts
I've done super glue, and I've done epoxy. Neither is, in my experience, quite perfect. But it helps. Heat shrink tubing is also pretty good, but it will slip off if you yank on it.
I've seen the cable end clips on bikes that look like they haven't been worked on in 60+ years. They look a little different, but I wouldn't worry about the C&V aspect of it. The ones we had in the shop in the early 80's were just like the ones out today.
rhm is offline
Old 03-15-11, 06:52 AM
Cottered Crank
Amesja's Avatar
Bikes: 1954 Raleigh Sports 1974 Raleigh Competition 1969 Raleigh Twenty 1964 Raleigh LTD-3
Quoted: 8 Post(s)
Liked 11 Times in 7 Posts
Cable crimp tips might not be period correct but they are the best thing ever invented. Just buy a bottle of 500 for $15-20 and have a lifetime's supply and never look back. Then again I use modern tires and brake shoes too. I guess I'm not a purist
Amesja is offline
Old 03-15-11, 07:01 AM
Glennfordx4's Avatar
Quoted: 90 Post(s)
Liked 137 Times in 45 Posts
I just use the cable end crimp caps in silver, I think I paid $10 or $15 for a bottle of 500. I also want to get some in black.
Glennfordx4 is offline
Old 03-15-11, 07:45 AM
FBoD Member at Large
khatfull's Avatar
Quoted: 30 Post(s)
Liked 7 Times in 7 Posts
Here's an idea if you don't want to use the crimp end OP, strip some bare copper wire out of something, small, 24ga or less, wrap the end of the cable, THEN solder.
While you're at it maybe tie and solder your wheels too
Idea?
khatfull is offline
Old 03-15-11, 08:32 AM
irwin7638's Avatar
Bikes: Sam, The Hunq and that Old Guy, Soma Buena Vista, Giant Talon 2, Brompton
Quoted: 102 Post(s)
Liked 106 Times in 48 Posts
I use epoxy with mostly great success. I let it dry overnight and cut it with a dremel rather than wirecutters.
https://simplecycle-marc.blogspot.com...-to-share.html
Marc
irwin7638 is offline
southpawboston's Avatar
Quoted: 78 Post(s)
Liked 182 Times in 89 Posts
Interesting!
southpawboston is offline
Old 03-15-11, 08:45 AM
Photographer
ScottRyder's Avatar
Quoted: 105 Post(s)
Liked 98 Times in 53 Posts
I use the standard aluminum crimp ends but then I'll paint them to match a color on the frame, handlebar tape or decals.
Scott
ClassicFuji.posthaven.com.archive
IG @scottryder.surf.cycle
IG @scottryder.fine.art
ScottRyder is offline
Old 03-15-11, 09:03 AM
RFC
RFC's Avatar
Bikes: many
Quoted: 18 Post(s)
Liked 16 Times in 13 Posts
Me thinks that concern about whether cable end caps are C&V may be approaching the obsessive.
RFC is offline
Old 03-15-11, 09:19 AM
PanGalacticGargleBlaster
Zaphod Beeblebrox's Avatar
Bikes: Upright and Recumbent....too many to list, mostly Vintage.
Quoted: 19 Post(s)
Liked 5 Times in 4 Posts
Similar to Epoxy although I haven't tried it I'd bet JB Weld would work well. When its dry you can sand and shape it and even paint it.
--Don't Panic.
Zaphod Beeblebrox is offline
Old 03-15-11, 09:23 AM
khatfull's Avatar
Quoted: 30 Post(s)
Scott
Hey, where's my pearl orange?
khatfull is offline
rhm
multimodal commuter
rhm's Avatar
True. The most C&V cable end treatment is a rough cut about an inch from the pinch bolt, frayed out about halfway. Rust is optional. Stainless cable is not.
rhm is offline
Old 03-15-11, 09:28 AM
Photographer
ScottRyder's Avatar
Quoted: 105 Post(s)
I haven't made up my mind yet what color to use. Orange, yellow, black or blue to match the bar wrap? These things take time!
Scott
Old 03-15-11, 09:40 AM
Chrome Freak
Rabid Koala's Avatar
Bikes: 71 Chrome Paramount P13-9, 73 Opaque Blue Paramount P15, 74 Blue Mink Raleigh Pro, 91 Waterford Paramount, Holland Titanium x2
Liked 26 Times in 14 Posts
I use heat shrink tubing mainly because it will come off with little effort.
1971 Paramount P-13 Chrome
1973 Paramount P-15 Opaque Blue
1974 Raleigh Professional Blue Mink
1991 Waterford Paramount
Holland Titanium Dura Ace Group
Holland Titanium Ultegra Triple Group
Rabid Koala is offline
Old 03-15-11, 09:43 AM
JTGraphics's Avatar
Originally Posted by BillP
Hiya ,
Bill P
Use silver solder on the stainless steel cable.
It may not be fancy but it gets me were I need to go.
https://www.jtgraphics.net/cyclist_bicycles.htm
JTGraphics is offline
Old 03-15-11, 09:52 AM
randyjawa's Avatar
Quoted: 1372 Post(s)
Liked 1,751 Times in 938 Posts
You can cut the head off of a brass or alloy spoke nipple and then crimp that into place. Clean it up a wee bit with a file and it will look just fine.
Personally, I use the ones I get in a bottle from the local bicycle shop. And, strangely enough, they are very similar to the ones on the twenty, thirty and sometimes forty year old bikes that I drag home.
randyjawa is offline
Old 03-15-11, 10:02 AM
missing in action
Chris_in_Miami's Avatar
Quoted: 42 Post(s)
Liked 49 Times in 29 Posts
I like the idea of soldering the ends for the convenience of being able to remove/re-thread the cable quickly without an end cap getting in the way, though I appreciate the caps when I get stabbed by an uncapped end.
For those who solder - do you solder the cable in place and let the brake/derailleur cable clamp act as a heat sink, or do you remove the cable before soldering to protect the cable liner?
Chris_in_Miami is offline
Old 03-15-11, 10:09 AM
JTGraphics's Avatar
You can solder if you like that area whip it down when hot and the size will not increase allowing you to still slide the cable in and out of the housing also.
Cutting can be done with a pair of wire cutters also on the solder area cuts clean
Old 03-15-11, 10:20 AM
Chombi's Avatar
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times in 27 Posts
For 80's and later classics, they are period correct as my 80's bikes came with them when I bought them . I've used them on my cable tips since the 80's and I can't go without them as I really hate frayed cable tips on a bike....yecccchhh..........and ouch too!
Chombi
Chombi is offline
Old 03-15-11, 10:36 AM
khatfull's Avatar
Quoted: 30 Post(s)
Scott
Hahaha, just busting YOUR chops for a change
khatfull is offline
Old 03-15-11, 10:41 AM
French threaded
PDXaero's Avatar
Bikes: many
Liked 4 Times in 4 Posts
A dab of clear nail polish works for me.
PDXaero is offline
Old 03-15-11, 10:43 AM
Cottered Crank
Amesja's Avatar
Quoted: 8 Post(s)
The crimp ends come right off with a solid yank with the side-cutters. Crimp a new one on when you are done. The side-cutters I have have a crimper built into them. I always have a side-cutters when I work on anything. I guess it is an electrician thing.
I fail to see what the big deal is with these crimps. They cost something like $.03 each when you buy them in bulk. Often you can re-use the ones you yank off anyhow. A bottle of 500 should last any home mechanic a lifetime. It's like ferrules, oil, grease, a variety of bulk bearings sized in jars, or any other consumable used when working on bikes.
Amesja is offline
Old 03-15-11, 11:12 AM
Chombi's Avatar
Quoted: 150 Post(s)
Attachment 193712
Crimps are great, but you do have a wide variety of them to choose from. I like the smallest diameters I can find, with the domed end, as some of them tend to be too chunky and look awful after you crimp them on.
Chombi
Chombi is offline
Old 03-15-11, 11:35 AM
Cottered Crank
Amesja's Avatar
Quoted: 8 Post(s)
I've got a bottle of XLC crimps sized 1.0-1.2mm and I've yet to run into a cable that they haven't fit on or looked bad. I've used them on deraileur cable and brake cable. Perhaps my personal level of "looks bad" is different than many other wrenches. They work fine and when crimped with my crimper they work well even on thinner cable.
BTW, nice VFR you have there Chombi.
Amesja is offline
