Mechanic help - chain length / caliper rub issue (pics)
Old 03-22-11 | 12:31 PM
macnab's Avatar
Bikes: Litton, Gunnar, Iro
I put together my daughter's birthday bike last night. Having trouble getting the 28 rando to fit, due to the chain length. I removed two links, and now I am caught between a too-tight chain on one hand and tire-to-brake caliper rub on the other . If the chain is a pretty basic KMC Z-410:
- Is it safe toput one of the links back in, i.e. pins not damaged by removal?
Wouldnt that push the axle off the back?
- Should I move to a half-link chain? (see pics of where axle is in the dropouts right now) Moving half link distance might be much better than a whole link. Reason I took two links out in the first place is that it looked like the wheel would be pretty far back in the dropouts if I didn't. Do you think I can out a whole link back in?
Alternate ideas? File the brake arms? Get a different (low-cost) brake with better clearance?
That's where the axle sits right now.
Tire spins right now, but there's no room for a pebble.
Thanks for any help!
macnab is offline
Reply
Old 03-22-11 | 12:40 PM
docboyd's Avatar
I'm pretty sure you can put a link back in...as long as its not busted or anything
docboyd is offline
Reply
Old 03-22-11 | 12:41 PM
GONE~
The cheapest solution would be a half link, which is about $3 or so at your LBS.
Squirrelli is offline
Reply
Old 03-22-11 | 12:53 PM
Cynikal's Avatar
Titanium Club Membership
20 Anniversary
Bikes: Too Many
If you put a link back in the axle would sit too far back in the track end. You ave 3 options: smaller tire, different gearing or a half link.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Cynikal is offline
Reply
Old 03-22-11 | 01:11 PM
striknein's Avatar
Goes to 11.
15 Anniversary
Bikes: 2015 Soma Double Cross
Half link++.
striknein is offline
Reply
Old 03-22-11 | 01:17 PM
macnab's Avatar
I didn't know I could buy a half link by itself. Thanks!
macnab is offline
Reply
Old 03-22-11 | 03:44 PM
lz4005's Avatar
coasterbrakelockup
Bikes: surly steamroller w/coaster brake, electra single speed cruiser, specialized rockhopper commuter, no-name single speed folder, 700c ultimate wheel, 24" unicycle, specialized bmx lsd, single seat single speed huffy tandem, pink upsidedown parade bike
Smaller tire or brake with better clearance.
lz4005 is offline
Reply
Old 03-22-11 | 04:01 PM
macnab's Avatar
Brake suggestion?
macnab is offline
Reply
Old 03-22-11 | 04:13 PM
FastJake's Avatar
Constant tinkerer
Cheapest: adding a half link.
Middle: A single pivot sidepull will give better clearance than a dual pivot. With a single pivot the tire will hit the brake at almost the same time it hits the seat stay bridge.
Most expensive but best (IMO): a frame with more tire clearance or horizontal dropouts instead of track ends.
FastJake is offline
Reply
Old 03-22-11 | 04:14 PM
JohnDThompson's Avatar
Old fart
20 Anniversary
Community Builder
Lower profile tire?
How wide is the present tire?
JohnDThompson is offline
Reply
Old 03-22-11 | 04:24 PM
macnab's Avatar
The tires are 28 Randos. Thinner tires are ruled out as an option, as the kid has skinny tire phobia. We ride dirt trails now and then in the park.
I also can't buy a different frame at this time. $$$
Thanks for all suggestions though, I appreciate the input, even when I can't use it for some reason or another. I bought the half link and will test it out when I get back in the garage at the end of this week.
Edit: Just ordered a single-pivot caliper brake. That plus the half link should resolve the issue for now.
macnab is offline
Reply
Old 03-22-11 | 08:04 PM
Build your own's Avatar
Bikes: Pake,Shogun,Nishiki,Motobecane
I see you ordered another brake, but for future reference,filing it a mm is not going to cause fail.I've done it to the brake and forkcrown to fit 28s on one of my bikes and never had a problem.Also,if it spins freely you're good to go.
Build your own is offline
Reply
Old 03-22-11 | 08:15 PM
Scrodzilla's Avatar
Your cog is slipping.
Sheldon Brown Memorial - Titanium
15 Anniversary
Bikes: EAI Bareknuckle
macnab - what frame is that? I want to see a pic of the whole bike!
Scrodzilla is offline
Reply
Old 03-22-11 | 08:23 PM
GONE~
Looks like Maxway dropouts, but not stamped.
Reply
Old 03-22-11 | 09:03 PM
Scrodzilla's Avatar
15 Anniversary
Close but no cigar:
Reply
Old 03-22-11 | 09:07 PM
yummygooey's Avatar
i smell bacon
Bikes: Geekhouse Deerfield, GT Edge Ti, Spooky Skeletor, TET Track, Ritchey P-650b, Bridgestone MB-3
Looks like a Swobo Sanchez/I remember a thread about them recently.
yummygooey is offline
Reply
Old 03-22-11 | 09:10 PM
Scrodzilla's Avatar
15 Anniversary
I think you're right!
Reply
Old 03-23-11 | 01:47 AM
macnab's Avatar
I am not done with it yet. Doing some work-work in Kansas City this week. I'll shoot real/final pics when I get back this weekend.
edit :yeah its the 46 sanchez
macnab is offline
Reply
Old 03-23-11 | 01:51 AM
Sixty Fiver's Avatar
Bicycle Repair Man !!!
Bikes: See my sig...
Lucky kid, great dad.
We want more pics.
Sixty Fiver is offline
Reply
Old 03-23-11 | 01:53 AM
docboyd's Avatar
what you gunna do with that other brake?
docboyd is offline
Reply
Old 03-23-11 | 02:16 AM
GONE~
Kansas
Dorothy?!
Reply
Bakersb
Singlespeed & Fixed Gear
6
06-08-22 10:11 PM
loudtiger
Bicycle Mechanics
27
04-24-13 09:08 AM
TwoFourOne
Bicycle Mechanics
27
05-02-12 03:36 PM
Shutter
11
04-20-12 09:53 PM
gutsofgold
20
08-29-10 03:45 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
