chain ring bolt question
Cervelo R3
Bikes: Cervelo R3
I have an old FSA single track crank and it is missing 3 chain ring bolts. I can't find a size label or specs for the bolts. Will most any single crank sized bolt work?
ie: https://www.benscycle.net/index.php?m...oducts_id=5564
thanks!
thanks!
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
Yes. But the set that you liked to is alloy and torx, neither of which many would recommend. You want steel and a more standard allen chainring bolt like this:
https://www.benscycle.net/index.php?m...roducts_id=628
Those have knurling on the female part which will seat them into your crank arms to make gear changes much much easier.
Cervelo R3
Bikes: Cervelo R3
thanks for the advice, I'll post a pic when the build is done (my marymoor rolling used part collection)
Quoted: 43 Post(s)
lockring bolts that seat themselves are definitely nice. In the event you end up with some that don't, a little loctite takes care of it just fine. You don't put it on the threads, but on the outside of the female threaded piece just before you install it.
2wheelcyclone
Singlespeed & Fixed Gear
5
11-13-18 09:00 PM
