Go Back  Bike Forums > Bike Forums > Winter Cycling
Carbon fiber in winter?
Winter Cycling Don't let snow and ice discourage you this winter. The key element to year-round cycling is proper attire! Check out this winter cycling forum to chat with other ice bike fanatics.
Old 10-28-04, 01:59 PM
無くなった
HereNT's Avatar
Bikes: I built the Bianchi track bike back up today.
I thought of this a couple days ago, just now posting. I bought a new seat earlier this year, and it's carbon. Is this a problem when it's -30F? I'd hate to have it get all brittle and shatter while I'm riding. Anyone used a carbon fiber seat in really sub-zero conditions?
HereNT is offline
Old 11-11-04, 04:14 PM
shot
shot's Avatar
Velo news Tech Reports had something about this last winter, but I can't find it anymore on the site.... Basically, they said that the structural properties of carbon fiber are not affected by cold temps.
shot is offline
Old 11-11-04, 05:59 PM
Trekaholic's Avatar
Bikes: Trek, of course.
If carbon fiber couldn't handle -30F, it wouldn't be used in jet wings or propellers.
Trekaholic is offline
Old 10-21-07, 08:30 PM
Have bike. Will travel.
Sirrobinofcoxly's Avatar
Bikes: '06 Orbea Orca, '03 Rocky Mountain Vertex 70, '05 Surly Steamroller, '06 Fetish Fixation
Well that pretty much ends that conversation.
Sirrobinofcoxly is offline
Old 10-21-07, 08:40 PM
JonathanGennick's Avatar
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 685 Post(s)
Liked 55 Times in 37 Posts
Good. Because I just got done putting a carbon bar on my winter bike.
Not that I needed carbon on the bike I ride through snow and slop. It's just that I had the bar laying around and figured I might as well run it and enjoy it.
JonathanGennick is offline
Old 10-21-07, 08:49 PM
mezza's Avatar
Bikes: Steel geared. Steel Fix.
Heat will cause CF to explode.
Cold will cause CF to shatter into a zillion pieces.
Even my dog knows this, he told me this morning while reading his copy of 'Ride' and posting on the forums.
Don't do it bro'.
mezza is offline
Old 10-21-07, 09:22 PM
Cat3.*....Cat2
asmallsol's Avatar
Bikes: A lot.
Correct. To add a little info on this, I'll comment.
Carbon fiber products being made up of two materials. Carbon, which is always brittle, and only becomes flexible as the radius of the threads are reduced to the point where when you bend it, it doesn't have a radius large enough to create a bending moment to fracture the material. The other is a plastic, that being Epoxy. Epoxy has a glass transition point (point where material turns from flexible to rigid) much higher then room temperature, so in use, its always in its "brittle" phase. Therefore, if its 90* or -30*, the composite is still below the glass transition phase, the properties are going to be about the same.
asmallsol is offline
Old 11-20-07, 11:45 AM
wtf
How does carbon react to rapid temperature changes. Say you are riding in sub 30 degree and then you bring your bike into a warm house. Will this cause any damage?
wtf is offline
Old 11-20-07, 02:38 PM
Sensible shoes.
CastIron's Avatar
Bikes: A few.
I don't have a CF seat, but the other CF bits in service (ergo levers, frame, frame parts, forks, etc) don't seem to mind the cold and suffer no ill effects from the 100*f swings from inside to out. No worries, mano.
Mike
Originally Posted by cedricbosch
It looks silly when you have quotes from other forum members in your signature. Nobody on this forum is that funny.
Why am I in your signature.
CastIron is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
