Questions about 1979 Schwinn Collegiate 3 speed
I recently bought a blue one from a friend and it needs some work, specifically new tires, brake pads (possibly brakes as well), and chain.
I've read that it needs 26 x 1 3/8 tires with a 590 BSD (if non-Schwinn tires, 597 if Schwinn) but the tires that are on it now say 27 x 1 1/4. Do they have the wrong size tires on them already?
Also, I'm a noobie at this bike stuff. Are brake pad sizes pretty standard throughout? I've googled and can't find what kind of brakes and size brake pads it takes.
Thanks so much! Oh, and can anyone recommend where to buy a chain guard? I only found one blue one available online and it was $40. Is that pretty standard for this vintage bike?
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
You need to look at what the stamping on your rims say. It should be somewhere near the valve stem.
As far as brake pads, most are pretty standard but there are different types for different caliper styles. I'd recommend Kool Stop Continentals, they are awesome.
Freewheel Medic
Quoted: 1453 Post(s)
Liked 2,196 Times
I might be able to help you out with a chaingaurd. I have an old Schwinn Breeze that is to be parted out. My guess is the chaingaurd will work. Do you plan to paint it to match your collegiate?
Bob
Bob
Quoted: 8 Post(s)
Some Schwinn rims were the odd 26" size . Since you state that it has 27 " tires on it , now, that is what you need. Just put the same size tire back on it . I pump those tires up to #70, no more , making sure the tire is seated evenly all the way around by pumping a little at a time , by HAND PUMP. I would suggest new tubes & possible new rim strips as well.
I second the Kool Stop Salmon brake pads,,, keep the sides of the rims cleaned with alcohol ,, & the above posters chainguard should fit.
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
Got pictures? I have never seen a Collegiate 3 speed with 27" wheels. But that doesn't mean they didn't make one.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Some of the things you mention don't jive with a Collegiate.
27" tires would be wrong with a Collegiate three speed. First, I never heard of a Schwinn three-speed hub laced to a 27" rim. That is very odd. Normally, it would be on a 26" X 1 3/8" rim.
a 27" tire won't fit on a 26" rim, so... I can only guess that someone changed out the wheel which would have been enormous work - especially on the rear wheel. Are you sure that the 27" wheel isn't just on the front? IF yes, I am going to guess that they just disconnected the front brake somehow and didn't bother with the complexity of changing the brakes.
smontanaro
Classic & Vintage
2
08-28-12 08:16 PM
