Scratched Seatposts Inevitable or Avoidable?
Quoted: 55 Post(s)
Liked 57 Times
I assume many folder owners use their bikes as tools for commuting. For those very protective of keeping things looking new, is there any way to avoid the scratching of the seatpost? Do other colors like black seem to hide it more or less? I guess keeping grit out of the seat collar is the first defense.
Bikes: Brompton, Dahon Vitesse D5
Quoted: 55 Post(s)
The anodized outer layer on Dahon seat posts will wear away slowly so go for silver if you don't want it to create an uneven tone. No reason for big scratches to occur unless hard debris/tiny stone fragments somehow find their way into the seat tube.
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
only way to not get sand in the seat tube is to avoid water.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
like a suspension fork , a wiper seal at the top of the seat post/ frame top could
clear away the big grit, before it's drawn in the space between.
but they are not made like that..
a rag in your pocket, can clean that, before you plunge the post into the frame.
so, rag in pocket, yes it's avoidable.
Location: Vancouver, Washington and Ocean Shores, Washington, USA
Bikes: 2 - 2007 Custom Bike Fridays, 2 - 2009 Bike Friday Pocket 8's, Gravity 29'er SS, 2 - 8-spd Windsor City Bikes, 1973 Raleigh 20 & a 1964 Schwinn Tiger
Had no problem with scratched seat posts on our 2005 Dahon Boardwalks until I "upgraded" to Aluminum seat post shims from the stock plastic ones - with the goal of eliminating any slippage. Little metal specs were being generated by the new combination and were scoring the seat post.
On my 2006 S1 I left the plastic shim in place and had no problems at all thru Feb of this year when I gave the S1 to my grandson.
Lou
Lou
I consider my folder as a tool to get around fast and easily while traveling. With all the moving parts in the bike that gets constantly moved, I expect wear in the finish of the components. Trying to keep everything "showroom" fresh would be a losing battle and just create frustration if you're that nit-picky.
Bikes: Mezzo D9, 2012 Giant Avail 2
Quoted: 13 Post(s)
My mezzo lost much of the black from the seat post within a few months. Definitely from folding/unfolding/riding in the rain.
Frustrating because it thoroughly polished off the markings for seat height.
Bikes: 2X dualdrive Mezzo folder,plus others
Quoted: 107 Post(s)
Best advise I have is;
Make sure you loosen the clamp fully and push the post straight down ,don't wiggle from side to side.
I purposely sandpapered the part of the seatpost which meet the clamp area on my Brompton to keep it from sliding.
Human Powered Vehiclist
Nothing lasts forever...
Abusing your bike is one thing, but getting normal wear and tear scratches on your bike is unavoidable. I used to be the same way when I first bought a "real" bike back in middle school. I was so concerned about getting scratches on it that I didn't enjoy it as much as I should have.
From working in the guitar industry, I can tell you that some consider it "cool" to have a well worn instrument, it shows character. Some people actually pay good money to have their guitars professionally "reliced," meaning they pay somebody to put scratches and digs on their guitar.
I now have the same approach with my current bike. Yes, take care of it but I'm not going pamper it at clean it with q-tips every night. It's my commuter rig, it's supposed to be looked well used. In fact I would feel like a poser if my bike was too clean and pretty. So stop thinking too much and ride your bike.
Quoted: 107 Post(s)
Abusing your bike is one thing, but getting normal wear and tear scratches on your bike is unavoidable. I was so concerned about getting scratches on it that I didn't enjoy it as much as I should have...............
Some folks even put clear 3M patches where there brake cables rub,personally i prefer my bike to have a well loved and used look.
Plus one. I did the same thing,cured the post from slipping down. Not only that but if done carefully i suspect one could use the sanded part as a permanent height marker. On mine it needs to be all the way up anyhow but should work for those where seat is not all the way extended.
BTW, on another blog, a fellow cut then wrapped a piece of inner tube at the bottom of the seatpost at a point where it will start preventing the seatpost from being pulled further up. That seems to be a great idea for those who don't want to "scratch" a marker on their seatpost.
Regulatori
Singlespeed & Fixed Gear
1
10-14-15 04:15 AM
ekaiko
General Cycling Discussion
5
11-21-12 03:35 PM
