What 700-series tire for Chesapeake & Ohio Canal / GAP ride?
Old 04-24-11 | 05:59 PM
Hello all, I just purchased a Windsor Tourist and am going to ride the Chesapeake & Ohio Canal / GAP trail later on this summer around July 4th.
I'm curious if anyone has some recommendations for tire to use? I'm guessing I'll want to use a 700x35 or wider, just wondering if there's a recommended touring tire for road & trail use around here?
Thanks!
frankgg is offline
Reply
Old 04-24-11 | 06:27 PM
Bikes: 1988 Giordana Capella | 1994 Cannondale T700 | 2007 Co-Motion Periscope
You'll be fine with a 32mm although I prefer a 35mm. I'll be riding a Vittoria Randonneur Pro 35mm for my trip in 3 weeks. The tread pattern might be an issue if it gets muddy but shouldn't be a big problem.
QueueCT is offline
Reply
Old 04-24-11 | 09:32 PM
CCrew's Avatar
Older than dirt
Bikes: Too darn many.. latest count is 11
I would consider 32mm to be the minimum, but I usually will pick one of the bikes running 35's or 38's. I've run it at speed/unloaded on my cross bike on 32's, and probably could have done it on 28's but it sucked a lot of fun out of it 100 or so miles in.
Had a pair of guys two years back that swore a road bike on 25's was perfect. Running north to south I ran into them at Paw Paw where they had stopped to buy foam pipe insulation for their handlebars and said they'd had a dozen flats between them.
You don't need agressive tread for the C&O, a road hybrid style tread design is perfect.
CCrew is offline
Reply
Old 04-25-11 | 12:23 AM
skilsaw's Avatar
Bikes: Cannondale t1, Koga-Miyata World Traveller
My personal view is to use the stock tires until they are worn out.
Kenda Eurotrek, 700 x 32c, presta valve tubes
The Schwalbe marathon racer 700x32 rear tire that came on my tour bike is about 1/2 used up so I've rotated the front and rear tires and will get another year, maybe two out of them. I start on a 700 mile (1150 km) trip in two weeks and feel confident about not getting flats. Now I've jinxed myself!!! See what you made me do!!!
skilsaw is offline
Reply
Estacado
General Cycling Discussion
20
06-16-18 05:53 AM
MAK
Touring
35
09-25-16 06:48 AM
DwarvenChef
Touring
5
07-16-12 03:33 PM
BetweenRides
Commuting
5
11-21-11 11:37 AM
Elantr025
Road Cycling
13
03-13-11 09:27 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
