tandem tires sizes - Trek
Old 04-27-11, 08:26 AM
Nigel
nfmisso's Avatar
Bikes: 1980s and 1990s steel: CyclePro, Nishiki, Schwinn, SR, Trek........
Quoted: 384 Post(s)
Liked 6 Times in 6 Posts
We got a great deal on a '94 Trek T50 this past weekend. The one thing that I believe is a bit crazy is the tires the previous owner installed - Continental Four Season 700c x 23. They look really weird on the rims - the tires maximum width is actually less than the maximum width of the rims. Great for removing the wheels for transport, but......
One of the first changes we're planning is the tires. From research, I understand that all of the mid-1990s Trek tandems had the same frame - so I am hoping for some input from riders of similar vintage Trek tandems on this subject. I haven't measured things out yet, but am thinking that 700c x 28 or 700c x 32 would be a good size, and am leaning towards Continental Gatorbacks. My prime concern is durability in urban and rural environments.
We had been considering a Mongoose AL Wanderer, and then adding some upgrades. We found the Trek, and calculated that it made much more sense economically, and is a better match for us. I prefer CroMo frames.
Thank you
nfmisso is offline
Old 04-27-11, 10:41 AM
Oldie. Boy, howdy!
Onegun's Avatar
Bikes: 2005 Trek T2000 tandem, Giant TCR, Eddie Merckx Majestic Ti, Fuji Team, Giant Revel 29er, Windsor Clockwork (Orange) fixie, and a BikTrix Juggernaut Ultra 1000 fat tire eBike
Here's a link to the BikePedia that shows it came with 38s!
https://www.bikepedia.com/QUICKBIKE/B...=T50&Type=bike
For urban warrior usage, belted or more flat-resistant tires of some sort are a good idea. Conti Gatorskins, Specialized Armadillos, and Schwalbe Marathons are some of the more common brands that tandemers swear by. If there is a "middle of the road" or "most common" tire size, my guess would be 28s, but somewhere on thetandemlink.com I'm sure TandemGeek has poll results to say definitively yea or nay.
BICYCLE - [[I]bahy-si-kuhl] - Noun :> A medical device used to correct the common geriatric condition of OFS, (Old, Fat & Slow), in a manner that does not induce brain-decaying boredom like walking or running.
Onegun is offline
Old 04-27-11, 11:46 AM
WebsterBikeMan's Avatar
Bikes: Nishiki Continental, Bilenky custom travel tinker, home built winter bike based on Nashbar cross frrame
The "middle of the road" to which OneGun refers is actually the middle of the road ridden by the most frequent posters to the Tandem Forum. My take on it would be that that may be the peak of the distribution, but you only see a few light teams with narrower tires, and the tail on that distribution goes out past 50 (well, at least 1.9").
The way I figure it, you want to look at the kind of load you'll be carrying and then from one of the tire pressure charts (such as the one Sheldon Brown references) you can see what tire pressure you need to run for a given width tire. Then look at the pressure range of your favourite flat-resistant tire and pick a width that lets you run that pressure, without being wider or narrower than the acceptable width for your rims. Yes there are tires out there that will take 180 psi and more, but I don't want to inflate my tires to that pressure with a hand pump, which is what I use.
By comparing our avatars you will see how we might come at it from different points of view...
WebsterBikeMan is offline
Old 04-27-11, 01:50 PM
Bikes: Stella
I'm sure you could fit 38s in there, if you chose.
My "LeMond" (90's Trek tandem geometry) bike came to me with a 28mm Bontrager on the front and a 32mm Vittoria Courier on the rear. Chosen for durability, I think.
Bontrager is a Trek house brand and you'll only find them at Trek dealers.
Schwalbes are nice. For that mater, Panaracer's Paselas would do the job for you too.
moleman76 is offline
Old 04-27-11, 02:20 PM
Nigel
nfmisso's Avatar
Quoted: 384 Post(s)
Onegun - thank you for reminding me of that link to the T50 information - I had actually looked at, and have it book marked, but missed the tire size - duh
I'll be looking at various options based on the information all of you provided.
Thank you !!
nfmisso is offline
Old 04-28-11, 07:11 PM
bike00's Avatar
Bikes: "97 Nashbar TweeTee, '94 Trek T100, '95 Univega Via Montega, '08 Trek 1.2, '09 Trek EX8, '00 Trek R200 Recumbent
We have a '94 Trek T100 and are running Panaracer Pasela 700x35c. Max inflation is 90psi. Good ride, few flats, plenty of clearance for fenders, if you want.
bike00 is offline
Old 04-29-11, 08:49 AM
Nigel
nfmisso's Avatar
Quoted: 384 Post(s)
We decided to go with Kenda 700x35, K193, Kwest, Black Cross/Road tires for the local learning rides. We probably won't get more than 15 miles from home in the next few months. My wife has not ridden a bike in years, and is now practicing on a stationary (she has balance problems and can't/won't ride a single)
In the fall, or later, depending how the Kendas hold up, we will be looking at tires again, probably Continentals.
Thanx everyone for the information.
nfmisso is offline
Old 04-29-11, 10:37 AM
wheelspeed's Avatar
Bikes: '06 Titus mtb, 2004 Trek T2000 tandem, '88 Merckx 753, '18 Emonda, '91 Cannondale mtb, '19 Trance 29er
Hi nfmisso,
I've liked our Continental Ultra Gatorskins so far. 700/28c used on roads and occasional jogging paths. Those jogging paths have some sections of rough and sharp stones. No flats yet in a few hundred miles. Our team, bike, and water/gear is probably around 365 pounds and I pump the tires to 120psi. If we spent more time on the jogging paths, and if our frame could fit a larger tire, I probably would go to the next size up like you recently purchased.
wheelspeed is offline
Old 05-02-11, 06:50 PM
3bluebikes's Avatar
Bikes: 2013 Trek Superfly AL 29er hardtail, 2005 LeMond Tourmalet, 2004 Cannondale Road Tandem
Liked 5 Times in 1 Post
Has anyone tried the Continental Gatorskin Hardshell? We would like to try them in size 700 x 28 for our Cannondale Road Tandem. Team weight is 355. We ride crushed limestone trails in addition to suburban and county roadways.
3bluebikes is offline
ericmerg1
Hybrid Bicycles
1
09-28-15 06:55 PM
libove
Road Cycling
1
04-04-15 10:28 AM
RiverdaleTandem
Tandem Cycling
10
05-26-14 07:24 AM
cobraLT250R
Hybrid Bicycles
5
09-24-13 04:56 PM
Jomayo112
Road Cycling
0
12-20-10 12:55 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
