walmart bike parts and accessories.
do you trust walmart stuff? I would never ever buy a bike from there, but I bought my bike light from there, and it's pretty good.
I just bought a bike chain from walmart. It didn't specify anything other than it's for 10 speeds and above. Doesn't even specify what it's made of. Cost $10.
Is this chain like most chains that I would buy from bike stores?
Quoted: 443 Post(s)
Liked 27 Times
The Walmart chains are branded Bell, but they're actually made by KMC. They're probably comparable to the cheapest chains you'll find at a bike shop. Cheap chains usually work okay, but they rust quickly because there is no corrosion resistant plating.
Young Fred
$15 at a bike shop and you could get a rust proof one. Otherwise, I'm sure it's fine. Rust-proof is over-rated unless you don't keep it oiled properly.
An ex-girlfriend of mine once bought a bunch of parts from Walmart, all Bell branded.
- The aluminum kickstand was very light and durable.
- The light wasn't very bright, but it shines enough to make you more visible to cars, just not enough to make the road more visible to you.
- The cycle computer was complete crap, resetting it itself constantly.
- The saddle and gel cover were also crap.
Also, someone gave me a wireless cycle computer from Walmart (again, Bell branded), and it works perfectly. Overall, I think Bell's stuff is hit or miss. But for the prices, you can afford to experiment.
Young Fred
Rolling along
Because food oils will turn rancid then gum up, attracting all sorts of debris and will lube your chain only for a short time. If you have to use something other than chain lube use a motor oil or some type of lube oil. Do not use cooking oil. Oil is cheap.
