Windbreaker too chilly, winter jacket not needed- what do you wear.
In the fall we get early Mornings with temperatures about 45-47 degrees.Windbreaker not enough.Yet, winter jacket too hot...What do you do to stay warm in these im- between weather conditions.?
Studs Terkel
Bikes: Pinarello Paris; Avanti Blade Comp; Tommasini X-Fire; Merckx San Remo 76.
I use Nalini Base Winter jerseys when the temp is about 0C to 12C.
Bikes: '03 Fuji Roubaix Pro; '03 KleinGi Attitude; '06 Soma Rush; '04 Surly Cross-Check; '06 Soma Rush; '07 Scott CR1 / Chorus
For the mid to high 40s, usually a long sleeve base layer with a short sleeve jersey over the top. Mid 30s to low 40s, I'll wear arm warmers and a vest, and a jacket if it's colder than that.
Two wheel escape!!
Bikes: Trek 5200
Dobber is on the mark...I use an underarmour long sleeve turtleneck for 40 - 55 degrees with a short sleeve over top. Under 40 degrees, use theunderarmour and a Canari windbreaker. Under 30 I go to a Reebock windproof running hoodie, with a great front pouch.
Bikes: Trek 4300 X 2. Trek 1000, Trek 6000
ZIPPERS ARE THE THERMOSTATS OF A CYLING JACKET. The more the better. Pit zips are especially nice on my Gore Tex jacket. They can take you from too warm to just right very quickly. Hardly anyone every mentions zippers but to me, they are very important. Aside from regulating your pedaling effort, zippers are equally if not more efficient at regulating your tempertature.
2-Cyl, 1/2 HP @ 90 RPM
Bikes: 04' Specialized Hardrock Sport, 03' Giant OCR2 (SOLD!), 04' Litespeed Firenze, 04' Giant OCR Touring, 07' Specialized Langster Comp
You need some vents in your wind breaker.
Or something like a light windpro fleece.
. . . rosebud . . .
Bikes: Diamondback Outlook
I wear short-sleeve underarmour t-shirt, regular short-sleeved jersey, and arm warmers. The jersey has a bit of a collar if I zip it all the way up, and I also bring along a skull-cap to use under the helmet in case it's too cold. Oh, and leg warmers.
Under 40F I ditch the underarmour and put on a thick fleece top on top.
So far I'm not a fan of wind/rain proof jackets since they don't seem to breath enough and I get uncomfortable. (I only have a nylon DWR-coated thing - with chest and pit zips. It's too hot.)
Quoted: 19 Post(s)
Liked 7 Times
What type of windbreaker? I have one for summer use, but it is not proof enough for winter. Another one I have is made of heavier grade polycotton and is good for below freezing.
I figured out a "huff test" for windproofs. Seal the material against your mouth and give a powerful huff. Ideally some air should be forced slowly through under pressure. If the air goes through quickly, it's for summer. If, like a goretex, nothing budges, then its for rain.
Location: The Alta Loma area of Rancho Cucamonga. About 45 miles east of Los Angeles, California. Uphill, downhill and across hill riding; not too level!
Originally Posted by foehn
A fleece pullover works great for me. Ventilated well, wicks well and easy to put on/pull off. And layers of course.
Foehn...Are all fleece pullover's the same..They all are made of wicking properties. When I think fleece, I think cotton..To me, cotton does not wick?
A couple of years ago, just at the tail end of a polyester-fleece fasion fad cycle, I picked up at a yard sale two pullover polyester fleece shirts, each with about a 9" zipper in the front from. I think they were originally sold by Target. One is red and the other blue and their back panels are "drop tail", that is they are longer in the back than in the front. I can go out in one of those on a cooler day (50-60° F) and they wick quite well and are just enough to keep the chill off, especially when I have to stop at lights and stuff. The red one is quite bright and the drop-tails cover my hips, which I appreciate when it is cold. The best thing? I am still wearing them, they still have alot of life left and I only paid 5$ for the pair!
I have a Wind-stopper Polartec Fleece Jacket I use when it gets colder. It is bright, pure yellow and is really nice to ride in. I paid quite a bit more for this than the shirts above, but I don't think it wicks any better, but it is nice when I am out when it is colder.
Do not get the cotton "athletic" fleece, or even the cotton/poly athletic fleece. They will just soak stuff up and stay wet. I went out today in a cheap, big ol' hooded sweat-shirt, 50/50 cotton poly, and it was pretty comfortable, but it was cool enough out to keep me from sweating too much. I got plenty of looks in it as it is High-Visibility Dayglo Chartreuse (lime yellow-green); I bought is because of the color and it was only 10 bucks--hey, what can I say, I am frugal. If I am out and it gets to the point that I am sweating and getting soaked, I am not riding in this shirt--it'll be tied onto my rack trunk.
I think a decent fleece overshirt/jacket combined with a good wicking jersey or wicking t-shirt is the only way to go in the relatively mild cold we have here and if it gets colder use more layers--didn't you know that our 40-60º winters are killers?
As others have suggested, I am talking about polyester fleece, Polartec or similar. . .
Car-Free Flatlander
Bikes: Sirrus
Last year I picked up a Columbia Titanium Rain Parka which has a separate zip front Polarfleece jacket/liner. Weather has been in the 40s and 50s so, when it's cooler I just wear a heavy shirt under the Polarfleece jacket. It's not cycling specific but the double zipper on the front and zip up pockets are very convenient.
When it gets too warm I just wrap it around my waist. When it gets cooler I zip it up as a turtleneck. When the weather gets cold I'll just add the windbreaker shell which has a hood, more pockets, and plenty of velcro.
Now all I have to worry about is my bottom half.
Stacy
Stacy
I just bought some long sleeve base layer t shirts..See how that helps..Plus a new pair of knickers are coming..In winter here, you could very well need prepare for low 40's at 7 am and 70's at Noon.
My suggestion: a light l/s shirt with wicking properties underneath your jersey and a vest with a mesh back and a solid front. These vests are amazing designs, with windbreaker fronts and ventilating backs, and the one I have folds up into a small roll, easily tucked into a jersey pocket. From what you describe, Cyclezealot, I would say a fleece garment would be too hot and not easily stored if you need to take it off on a ride. There are numerous sources for relatively inexpensive undershirts.
BTW, to support the company, Malden Mills, I buy only Polartec fleece products. Several years ago, when the company's plant burned down, the owner, apparently out of loyalty to his employees, kept them on the payroll until he could rebuild and put them back to work. I appreciate his altruism and concern for the welfare of his workforce.
ex frame builder
Liked 5 Times
Sometimes you are going out for a long ride and starting early when it’s cold, but you don’t want to wear extra clothes because you know it will warm up later. A sheet of newspaper under you jersey will keep the wind off your chest and keep you very warm and you can dispose of it later when it warms up. This is one of those low tech tips that does work.
History, photos and tech articles on "Dave's Bike Blog." 'dave moulton' Registry including a Picture Gallery https://www.davemoultonregistry.com/
