Saddle sores
Saddle sores
Hey, my main problem is I've always ridden on big padded beach cruiser seats. Now that I'm riding on mountain bike type seats more often it seems like I've spent alot of time sitting directly on my balls, and it's killing me. I was wondering if anyone knew of a remedy for this, I'm thinking of switching back to a beach cruiser seat.
In the right lane
Try the following:
1. Bag Balm... lather liberally before riding.
2. Take several long baths week. The sores love to be soaked.
3. Use some zinc ointment before going to bed.
4. Change you bike shorts every month whether you need it or not.
Hot in China
Bikes: Giant Lava
perspiration is right, and it might be your seat.
It might be that you have the seat tilted with the front too high, that will put more pressure on the front.
It might be a badly made seat.
You might have non-standard sit-bone geometry (closer together or further apart than usual).
It is hard to tell without more detail on your part...
z
z
Intrepid Bicycle Commuter
Bikes: 1976 Motobecane Grand Jubile, Austro Daimler 'Ultima', 2012 Salsa Vaya, 2009 Trek 4300, Fyxation Eastside, State Matte Black 6, '97 Trek 930 SHX, '93 Specialized Rockhopper, 1990 Trek 950
Quoted: 76 Post(s)
Liked 94 Times
Maybe we should define our terms. Saddle sores are generally boils on your butt. If your balls are aching, that is another issue entirely.
Bikes: 2012 Cinelli Mystic Rat, Nashbar CX
Take a look at your seat adjustment. You may need to point the front of the seat down a little so you can ride back on the wider part without placing too much pressure on the ol' scrod.
Another thing that I have found that works is Desitin. Yep the diaper-rash stuff. I keep a tube of it in my backpack just in case. It will help the chaffing heal much quicker, and it does give you some relief after the initial stinging when you first apply it.
Hope that helps.
Hope that helps.
Quoted: 2604 Post(s)
Liked 1,928 Times
Try some bike shorts to lift your equipment out of the way. If you're too shy (you'll get over it!), there are some mountain bike shorts with baggy outers.
Bikes: 2007 Giant Cypress DX, Windsor Tourist 2011
Quoted: 24 Post(s)
It sounds like you are sitting on your fleshy tissue rather then on your sit bones. This could be because you have a wide rear end and this forces you to 'straddle', rather then sit on top of your saddle. If this is the case, you might need a saddle that is a little bit wider.
Since we are all different it can take a while to find the right saddle, as saddles that work for others might not work for you. I hear that some bike shops have a 'sit bone' measuring machine that can tell you how far apart your sit bones are, and then recommend a saddle. Barring that, most of us just try several saddles until we find one that works.
Velocommuter Commando
My vote is with the others. Sounds like you need to adjust your saddle
It's definately not too high in the front. I've actually already lowered it to the point of sliding down it. That creates a whole new set of equally disturbing problems, but I'll refrain from going there. I think what I need is one of these.
Middle-Aged Member
Bikes: Bianchi Infinito CV 2014, TREK HIFI 2011, Argon18 E-116 2013
Quoted: 24 Post(s)
so, I may be non traditional, but I move the team up into a well supported chamois so the bag and the team are above where the seat is. You don't sit on top of you balls when in a usual chair, why should you while riding? and pitching the seat down just makes your wrists hurt more!
if it is not a crushing pain, but rashes from excessive heat due to thigh friction: perhaps some butt'r or similar to reduce friction,
if it is your butt... it's never good to confuse a hard ride a with busing from an improperly sized saddle... I would say this one is less likely as you don't clip in.
Hot in China
Bikes: Giant Lava
Every now and then I dont get adjusted correctly at the beginning of a ride, and have to reach into my pants and adjust... I just do it when there is nobody around.
z
z
2 Fat 2 Furious
Bikes: 2009 Specialized Rockhopper Comp Disc, 2009 Specialized Tricross Sport RIP
If your saddle is too far back it might cause you to sit on the narrow part of it rather than plonking your butt cheeks on the widest part at the back. If the nose is too high it will compress the wedding vegetables in all sorts of unpleasant ways. If it's too far back and tilted too high you get double the fun.
Assuming you're not of a particularly unusual shape try moving the saddle forward and dropping the nose slightly. Adjusting the angle may take a bit of trial and error, don't drop the nose too far at first or you'll slide off the front.
Non sibi sed patriae
Bikes: 2012 Surly Ogre (Shrek), 1985 Raleigh Kodiak, 1995 Specialized Hard Rock, 2009 Citizen Miami
I have not heard that before, thanks contango.
Seat height adjustment can also have a bit to do with mashed err, vegetables. I have found that while tilting the seat, I need to adjust height as well.
Health Goals
Walk More
Bike More
Hike More
Move More
Eat Less.
https://thestoutdog.blogspot.com/
https://www.facebook.com/TheStoutdog
Health Goals
Walk More
Bike More
Hike More
Move More
Eat Less.
Quoted: 52 Post(s)
Liked 17 Times
This will sound counterintuitive but the seat should be level or even tilted up a bit at the nose. It sounds like this would squash your vegetables even worse but what it actually does is force your weight back onto your butt instead on the veggies.
Another counterintuitive point. Cushy seats can often be more uncomfortable than hard ones.
Goonie
Bikes: Raleigh R600, Trek 6000, Schwinn World Tour single speed, Old JC Penny single speed beater, Various other old beaters
Noseless saddle = no more numb genitals for me, but a lot of people don't like them (the noseless saddles that is).
Ridin for the sweat
Bikes: Giordano Libero
Hope that helps.
2 Fat 2 Furious
I guess that might work for some, it didn't work for me. I had all sorts of issues with numbness in that area until I tilted the nose downward slightly.
Saddle sores are more of a skin hygiene issue, than anything else ,
carbuncles are a bacterial inflammation in pores and hair follicles.
In the right lane
Here's a good article describing it and ways to deal with it. https://www.rivbike.com/article/misc/saddle_sores
