Go Back  Bike Forums > The Racer's Forum > Track Cycling: Velodrome Racing and Training Area
Chart Wanted: Cadence @ a Certain Speed..?
Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
Old 11-04-04 | 08:02 PM
-= vegan =-
Bikes: Kona Haole (Tanya Dubnicoff's old bike)
Hi all, i'm sure there's gotta be something like this out there..
I'm looking for a chart which shows what gear you need to be in to maintain a certain speed at a certain cadence.
For example, if i wanted to ride ~40kph and spin ~100rpm while at that speed, what gear would i need to be in?
Thanks!!
Dave Noisy is offline
Reply
Old 11-04-04 | 08:08 PM
Not sure how scientific this is because it doesn't take into account weight of rider, flat vs. hills, etc. But I find it pretty useful to get the proper shifting sequence.
https://www.panix.com/~jbarrm/cycal/cycal.30f.html
goonda is offline
Reply
Old 11-04-04 | 08:20 PM
HereNT's Avatar
無くなった
20 Anniversary
Bikes: I built the Bianchi track bike back up today.
Man, I can't find it any more, but there's a forum that's all track bikes. I think that there was a chart here that listed gear vs cadence vs speed vs time per lap on different length tracks...
HereNT is offline
Reply
Old 11-04-04 | 08:31 PM
Map tester's Avatar
I am not a car
20 Anniversary
Bikes: Giant Revel 1, Surly Ogre
Try this: HPV Drivetrain Analyzer or Sheldon Brown's Gear Calculator
"Bad facts make bad laws." FZ
Map tester is offline
Reply
Old 11-06-04 | 12:44 AM
-= vegan =-
Thanks guys, the Panix and Brown's ones are great!
HereNT - you prolly mean https://www.fixedgearfever.com/ - i'm on there as well, thanks!!
Reply
Old 11-06-04 | 09:21 AM
HereNT's Avatar
無くなった
20 Anniversary
Yeah, that was it.
HereNT is offline
Reply
Old 11-06-04 | 10:19 AM
For the math unchallenged here's how to figure it out:
the chain ring to rear cog tooth ratio is the gear ratio which means that for every turn of the crank the rear wheel turns front ring # teeth/rear cog # teeth times more. This ratio is then multiplied by the wheel circumference which you remember from geo as 3.14159 x the diameter (most wheels are 700mm(27.56 inches) or 27 inches). Therefore, multiple the 3.14159 x 27 x tooth ratio x cadence and that's your speed in inches per minute. To convert to mph multiple that number by 60/(12x5280).
Example: riding a 42/17 at 100 cadence on 27" wheels (if you ride 700's or other sizes just change to whatever diameter you have on the rear wheel
100 x (42/17) x 3.14159 x 27 x 60/(12 x 5280) = 19.84 mph
A mental exercise I used to do while training was simply scale the speed by the gear ratio knowing that a 42/17 or 66.7 inch gear is 20 mph at a 100 cadence. If I was riding a 52/14 which is a 100 inch gear than my speed would be close to 1/2 x faster or 30 mph. These were the days just before inexpensive speedometers were available
boyze is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
