How do I adjust these handlebars?
I've been having a lot of pain in my hand/wrist and believe a handlebar adjustment can help me out.
https://imageshack.us/photo/my-images/405/dscn2891o.jpg/
there are three allen bolts, 2 on the side and 1 on the top. And there is one very large "nut". I assume the nut controls the height while the bolts control the angle?
Thing is, I don't have a wrench anywhere near that big, will I need to buy one is there some other way of going about this?
thanks!
thanks!
Quoted: 2026 Post(s)
Liked 1,096 Times
The "nut" is the lock nut for your headset and doesn't have anything to do with the stem's height or angle. Don't touch it.
Riding the road to PARADISE...RIP
The two bolts on the side control the angle of the stem, the one on the top controls the height. There are also one or two in the front that clamp the bar in place, if you need to rotate the handle bar itself. Like Hillrider said, don't touch that nut.
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,923 Times
look closely at the 'quill' portion of the stem (the part that sticks into the fork) there is a an "minimun insert" or "maximun height" marking. besure this is out of sight below the nut
Sugar "Kane" Kowalczyk
Constant tinkerer
That's what I thought when I tried adjusting one of those stems too. If I remember correctly, only one side is meant to loosen. The other side stays put. Try loosening one side and taking the bolt completely out. It took me a while to figure the stem out, I suspect you may be in the same situation.
bike whisperer
Quoted: 1526 Post(s)
Liked 718 Times
Your sore wrists and hands are prolly just a result of having your brake levers too high. You should be able to grasp them just by moving your fingers, rather than having to rotate your whole hands back. I know the backs of my hands get sore when riding a flat bar bike with the levers too high.
So looking at the bike from the right, your levers should be around 4:30-5:00 on the bars, depending on your position on the bike.
It's very common for levers to be mounted a bit too high, like this:
Move them lower, and not only will your hands stop hurting, but you'll be able to get onto the brakes quicker.
Yeah I feel like my brakes are way too far away. I have to adjust my hands just to keep my fingers near them =(
I see what you mean regarding the adjustment, now I just need to figure out how to do that =p
thanks!
thanks!
rch427
Alt Bike Culture
2
10-02-10 08:27 PM
