Have any of you guys tried the Schwinn no pressure saddle?
Bikes: Raliegh M-50
Just curious. Sure does look comfortable,a little wide in the saddle and no horn to prevent smashing the pelvic and groin areas. I'm considering getting one but I haven't heard any reveiws. Good idea for the seat?
Its an interesting seat:
https://www.amazon.com/Schwinn-No-Pre.../dp/B000DZGLVY
I would be interested in opinions too. Its very economically priced. I need to get rid of my Bontrager seat on my Trek 7.3. Any thing over 15 miles and my buns are on fire. I usually go the Brooks route but I need a seat that does not need care - keep dry, dubbbing etc as my Trek is a simple knockaround/commuter bike and I also dont want to spend $80+.
Bikes: Raliegh M-50
I've seen a spilt level seat with the same concepts,but it was going for $70 or more.At $16.00 I guess you could add a gel saddle that you can modify to fit it.
Bikes: 2009 Rocky Mountain RC30 D
A lot of people end up angling the front downwards to compensate for this and this leads to other problems, like constantly sliding forward off the seat. You are right to think that they will indeed alleviate the pressure on the areas you mention, but, you shouldn't have to trade one evil for another, imo.
If you only plan on riding periodically and not for any great lengths, then the seat would probably be okay for you. Around the block or the neighbourhood type of thing. If you are more serious about biking than that, there are better choices out there.
Bikes: Specialized Sirrus Elite Disc, Specialized Roubaix Expert
These types of seats (general shape) are not that great. You will find that the underside of your upper thighs will be binding against the edge of the seat during each peddle stroke.
The only bike I could see this working reasonably well on is something like the Electra Townie or other similar semi-recumbent bike. When you are kicked back in a relaxed position like such bikes provide, it would seem less likely that you would get the rubbing on the backs of the thighs or slipping forward off the saddle. The beauty of a traditionally shaped saddle is that it provides something for you to clamp between your legs or thighs.
The other thing I don't like about this type of saddle is that it forces you to sit on the soft, fleshy part of the hind end which is the worst place to try and support your entire body's weight. Our butts were just not designed for such sitting. If we were intended to be able to sit for such long periods of time on irregularly shaped objects, we would have a huge, blue and red thick, tough, and fleshy pad on our butts much like a baboon. I seriously think that such gimmicks as this seat are an answer to a problem that didn't need to exist.
Bikes: Raliegh M-50
Which is why I don't run off and make purchases any more.Thanks for the replies. Another question,what about the split seat with no horn? It's designed for performence and comfort as well.
See my comments above. I think a split seat with no nose or horn as you call it would be pretty much the same thing. Most traditional saddles that are split to avoid pressure on the groin area which is typically have the split up in the nose of the saddle where such pressure is located.
Bikes: Raliegh M-50
Another one that looks much better,(and pricier!) is the ISM Ergonomical saddle,built for touring and comfort as well is real high on my list right now.It is medically tested,and looks really,really comfortable.This saddle is one I can see myself getting,especially since I'm not into jumping or doing any stunts on a mountain bike.It would really do well on a hybrid,but I can always move it when that time comes.
This seat isn't split,it has a comfort space which allows less pressure on the groin area while cycling and doesn't give up any performance.
The problem with ANY seat is that it was not intentionally made JUST for you. You can read a thousand reviews and spend a ton of money but at the end of the day you are guesstimating on any seat. Last summer, I spent $160 on a Specialized seat that was "sure to fix" my rear end problems. After 10 miles I was in agony. The ONLY success I have had is with a Brooks B17 -
https://www.nashbar.com/bikes/Product..._200276_200413
this seat is almost "made for you" as it moulds to your butt over time - very comfy. The only downside is that its like Sam Malone's Corvette as you really dont want to ride on it in the rain because it can ruin the leather (stretch it out)
Bikes: Trek 820, Giant Sundance DX
My wonderful wife bought me one of these when I first started riding to help me with some serious saddle sore...serious enough for me to consider quitting riding.
I did have issues sliding forward as mentioned above, but it did give me time for my arse to recover from the massive beating it took early on.
I have moved on to a Schwinn Memory Foam seat now, saddle problems are getting under control.
Make sure your seat height is appropriate, the fore/aft is reasonable and that the saddle is for the most part level. A micro adjustable seat post is often helpful with the tilt angle.
If you have done that and still feel that you have extreme pressure on the groin area then lower the seat post a half inch and see if that makes a difference good or bad. You don't want to lower it too much as that will cause other issues, but, there is some leeway to play with.
I also agree with magohn regarding the Brooks.17 or one it's variants, the B.17 Imperial or the Flyer for example.
The Imperial has a cut-out design to alleviate the pressure you appear to be suffering from. https://www.brooksengland.com/en/Shop...d=B17+Imperial
If you feel that you want to continue cycling in the years to come, then looking at the Brooks is an option well worth it.
wallbike for example, provides:
:We give a SIX-MONTH UNCONDITIONAL GUARANTEE on new Brooks and Berthoud leather saddles.:
https://www.wallbike.com/catalog/saddles
One more step forward...
Bikes: 26" Schwinn Cruiser/ now wishing I'd bought mountain or hybrid bike.
I have that no pressure schwinn saddle and totally love it. Rode 10-13 miles at different times and never a problem. I have mine tilted back just a tiny bit.
Likes For WJordan:
I've heard lots of great things about the Brooks B17 also, but I'm a bit on the cheap side, and also not sure if I want to deal with stiffness during the break-in period and also having to rub leather conditioning cream on it periodically (I'm into low maintenance, especially for saddles). So, I've been doing some research and I'm planning on buying the Planet Bike Anatomical Relief Saddle soon -- thought it might be of interest to you too.
Bikes: Raliegh M-50
I didn't know Brooks saddles cost that much ! I guess if I had a better bike I would want to spend money on a good seat. Not sure if I want to spend the cost of my bike on a new saddle.
Bikes: 15 Specialized Crosstrail, 83 Schwinn Traveller, Fuji Sport
In 2 places on one of my regular rides there are long downhill sections where the speed gets up to 25 or 30 mph with a relatively tight turn at the bottom.
A sensible person would brake and take these turns at a lower speed. Not having the luxury of being a sensible person myself I find I need to take these turns at speed.
Tight turns require leaning and I can't imagine trying to do that on a seat without a horn.
Likes For Laserman:
Love it
I put the schwinn no pressure on my road eBike 12 months ago. - Now I'll add that I'm heavy, very heavy and I've done over 1600km/1000miles on it in almost 12 months.
Previously I had a wide gel regular bike seat, and after half an hour I'd be very uncomfortable.
but with the schwinn noseless?
I have ABSOLUTELY NO PROBLEM riding 3 hours on this seat. (The most I've done is 5 hours in one day). ZERO pain, ZERO discomfort - at least in my butt and groin area... same couldn't be said for my legs after that long.
On the first long ride my partner tried my seat out and it took her 30 seconds to say 'why tf didn't you get me one of those, order one tonight'.
If you're skinny and you enjoy having your prostate crushed then sure, go for the brooks, I've sat on one of those too... it's cheaper than a vasectomy I guess
Bikes: Modified 26 inch frame Schwinn Varsity with 700c wheels and 10 speed cassette hub. Ryan Vanguard recumbent. 67cm 27"x1 1/4" Schwinn Sports Tourer from the 1980's. 1980's 68cm Nishiki Sebring with 700c aero wheels, 30 speeds, flat bar bicycle.
Quoted: 131 Post(s)
Liked 141 Times
Nose saddles and prostatitus issues
One bad case of Prostatitus brought on by the horn of my Brooks B67 saddle was enough for me to give noseless saddles a try. After a lifetime of riding horned? saddles the switch was not all roses and ice cream. I tried the two models of Hobson saddle for sale on the internet. I also bought a Spongy Wonder saddle from the Canadian manufacturer. I found that I had to learn a completely different way of adjusting the saddle height, angle, and the width of the saddle pads from one another. This has taken the better part of a year to fine tune these saddle. I had a very hard time getting the Hobson Easyseat adjusted properly and gave up on it. I bought a Hobson Easyseat 2 and this seat proved to quite comfortable from the start on a flat bar all road type bicycle. I then bought a Spongy Wonder saddle and put it on my other all road bicycle with an upright seating position. For reasons unknown my right hip bone would slip off the right pad. I started adjusting the pads, their distance apart from one another and their angles. At this time this seat is working very well. I ride typically from 10 to 20 miles on my rides. I recently built a drop bar bicycle up after 30 yrs of not having one and put the Hobson Easyseat that didn't work out on my other bicycles on it just to get it up and running. Presto this seat loves a more forward leaning position and has been the best of the lot on that bicycle. I agree with other riders mentioning the lack of control feeling especially at speed. It took months of riding but I now do everything I ever did on nosed saddle and don't have either control or pain issues. My prostatitus disappeared after switching to these saddles and the comfort of not crushing yourself is wonderful. Noseless saddles are probably not for everyone and I wouldn't have switched until I found out that Prostatitus was terrible enough to see me through this major change.
Bikes: 1986 KHS Fiero, 1989 Trek 950, 1990 Trek 7000, 1991 Gary Fisher Hoo Koo E Koo, 1992 Trek 1400, 1997 Cannondale CAD2 R300, 1998 Cannondale CAD2 R200, 2002 Marin San Rafael, 2006 Cannondale CAAD8 R1000, 2010 Performance Access XCL9R
Quoted: 284 Post(s)
Liked 385 Times
I'm quite glad I didn't have a beverage to my mouth when I read this!!!! This describes me to a T!!! Well. The not being sensible part...
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,124 Times
$135 for a Brooks B17 straight from their website (110 English pounds) - about the same price as a Specialized Power Comp saddle (also a great saddle for alleviating numbness - for me at least) - or , accounting for inflation, about the same price as any decent saddle out there ---- A quick check of a price for a re-issued Selle Italia Flite saddle (the go-to saddle of the 90's) shows it is around $135 as well
They costs what they costs
I just think people going the Brooks route need to be prepared for it to be uncomfortable as hell at first, especially if they're used to soft squishy gel saddles and the like. It was more uncomfortable at first than I'd anticipated, but I stuck it out, and it was worth it.
The value of a Brooks isn't how its price compares with the price of your bike. The value is in how comfortable it is, and the value that comfort has amortized out over potentially thousands and thousands of hours of riding on it. If an $80 saddle makes your $75 bike comfortable enough for you to stand riding it, then it's worth it. Is it worth 4 or 5 cents an hour to ride in comfort, vs. saving that 4 or 5 cents and hour and riding in discomfort? I guess that's a personal decision. For me it's a no-brainer.
As far as the "cheapskate" arguments I'm sympathetic to a degree, but I'll spend hundreds and hundreds of hours per year in the saddle, and amortizing out the up-front cost of something like the Brooks over the use I'll get out of it, it's really a matter of paying a few cents/hour of riding to remove saddle discomfort almost completely from the equation. That's solid value right there.
ETA: everyone's body and experiences and whatnot vary, so it's possible something like the Brooks isn't the answer for literally everyone, so I can only contribute my own experience and views on the subject.
bbeasley
3
07-07-12 09:34 PM
