DT Swiss Onyx hub for touring?
Bikes: Leader 722TS, Surly Cross Check, GT Outpost, Haro Z16, Trek 1000
So being that this hub is not longer in production finding info on it is kinda hard. I got one of these super cheap recently and was considering using it as the hub for my new touring rear wheel. Everywhere I read on the net these days says to use either XT hubs or Phil. This seems like an awfully large gap in quality. I have had great luck 700c touring on my DT Swiss 240s hubs. These days I am more interested in touring with minimal gear (20-30lbs with food). I am also switching to 26" for more comfort.
Anyway, the rear build I am thinking is the DT Swiss Onyx I got (though mind you its only a 32h, hope I wont regret it, though my 240s hubs were 32 also) laced to Sun Rhyno Lite rim with Alpine III spokes. Does this sound like a good build or would I be better served by going with the XT hub, 36h and Rhyno lite rims? I weigh 250lbs btw.
Thanks you very much.
I built some DT Onyx/Velocity Synergy/WS DB wheels back in 2005, after getting an excellent deal on hubs. At the time, DT Hugi were very popular (no longer made, replaced by current 240/340 series hubs). The Onyx were DT's "cheap" hubs. I built 3 wheels for use on 2 bikes: 36h disc rear, 36h disc front, 32h rim front. I used them for 6,000 miles, nearly all on pavement, and never had a problem.
I recall discovering a loose locknut (minor issue) on the rear hub at the end of this period, when I cleaned and regreased bearings. The rear hub has 1/4"/ 6mm ball bearings on the drive side, and a cartridge bearing on the non-drive side. All the front Onyx hubs use pressed-in cartridge bearings.
So, in my experience the DT Onyx were good hubs, suitable for touring duty.
https://www.mtbr.com/cat/tires-and-wh...93_127crx.aspx
A 36h Shimano XT hub may have a little advantage longevity-wise, built the same way with same rim/spokes. An offset-drilled rim like the Velocity Synergy would help even more, since it will take about half the dish out of a std 135mm XT wheel.
through fate, it may be in a wheel that gets damaged,
then since most shops would more likely have a shimano hub wheel
for replacements, in stock,
you can mail the DT hub home to be part of another wheel build..
Bikes: IF steel deluxe 29er tourer
My Hugis have lasted 40k miles with just basic servicing. I'd replace the (sealed cartridge) bearings, but I'd need a $170 tool kit.
The 32h should be fine if you stay on asphalt - especially with 26" wheels.
