FD that will shift to a 44t big ring using Ultegra 6703 STI triple drop bar shifters?
Bikes: IF steel deluxe 29er tourer
Does anyone know of a front derailleur that would work with an XT 10-speed triple crankset and Ultegra 6703 10-speed triple STI shifters? Ultegra shifter cable pull is not compatible with what is required by XT front derailleurs, and the Ultegra 6603 and 6703 front deraillers can't shift to a 44t chainring.
I can no longer find replacement RaceFace Race chain rings for my "compact triple" 46/34/24 RaceFace Turbine (9-speed) crankset, which I run with Ultegra 6503 9-speed triple STI shifters and an Ultegra 6503 front derailleur. The latter two components are also difficult to find, but an IRD Alpina-d FD can substitute for the Ultegra 6503 FD. I really would rather not go back to bar end shifters.
I would be fine touring loaded with MTB gearing. If I find that I'm not using the big cog, I could always switch to a tighter cassette when the first wears out.
Thanks in advance for your help!
with other aftermarket chainrings sharing the same bolt pattern.
lots of feedback on the shifter cable pull ratios being different running road brifters
and mountain FD's. read up what others said.. on this forum
,, part of why I prefer Bar end shifters .
Though not RaceFace brand, You should be able to replace them,
Yes, lots of discussion, but no conclusions other than "bar end shifters". One can only hope....
In your opinion, which are the best? (110/74bcd 5-bolt)
+ several other odd number tooth counts.. 45,47, etc..
get the 24t in Stainless steel, I got one from Stronglight, another French company,
and you will never need another..
Surly makes a stainless steel 110-34t, but its lacking the early shifting tooth profiles,
and shift pins, for aiding your brifters quick shifts upward..
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,200 Times
If you want the best option, find a Tiagra front derailer. Best front triple derailer that Shimano makes. Far better than the Ultegra or 105.
Or you could just get new rings. Cambria has Race Face 94mm BCD rings in 46 tooth for $15.
Stuart Black
Stuart Black
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
Use this from IRD: https://www.interlocracing.com/cdfrtder.html
Alpina Front Derailleur
Same performance level as the CD, but designed for triples. Will work with standard road triple cranks, but it is optimized for smaller rings such as 48-36-24t or 50-36-30t.
• Braze-on style, but this includes an adapter clamp for 28.6, 31.8 or 34.9mm.
• Alpina-d is designed to work better with Shimano's drop bar/STI shifters.
Sure they can! Which is to say: my touring bike has an Ultegra 6603 crank and the corresponding STI shifters working with a Deore 9-speed MTB trekking crank (48/38/26). I don't see any reason why the same setup wouldn't work with a 44t outer ring, assuming the FD height is set appropriately. I'm using a Shimano crank and found the only trick was to remove one of the spacers from the drive-side of the BB. That moved the chainline 2.5mm closer to the frame, which allowed the Ultegra FD to shift into the large ring.
Thanks for the responses. TA rings are big in Europe, not so much here (PWC, HC). So the next time I'm putting together an online order of stuff best available there (like silver Alpine III's) I'll buy some 110 bcd TA rings.
I have an Alpina-d FD so I'll try it with a 9-speed XT crankset. I couldn't care less about having 10 cogs and 9-speed consumables will be around for a long time still. I don't know about the chain line of the XT versus the RF Turbine cranksets. Will I have trouble?
Awesome thank you very much. I don't have any parts yet, other than those I've mentioned, because I'm looking for (and found, thanks to you) confirmation of theory before actually making the investment. Cheers. Lots of options now.
The bikes that Machka and I use most each have Shimano MTB cranks (square taper, Hollowtech and external bearings, and either Ultegra triple or Tiagra triple derailleurs with Ultegra or Tiagra shifters. That's three bikes. All perform well for touring and randonneuring purposes.
Tend to agree with cyccommute that the Tiagra is a pretty good derailleur as far as value for money and performance.
Ah, but the available 6603/6703 and unavailable 6503 Ultegra FD's are completely different shapes and do not shift to 48t and smaller chain rings the same way. The devil is in the details.
I'm not quite sure what you're saying here. FWIW, I've got an Ultegra 6603 FD and it shifts the chain around on my Deore M532 26/36/48 9-speed trekking crank just fine. Shimano will tell you that it shouldn't work, but in actuality their specs are extremely conservative. If you want to go much smaller than a 26t inner ring, you might need a Deda Elementi Dog Fang, N-Gear Jump Stop, or other chain guide.
by using a band adapter, and a 'braze on' FD, the possibility of changing the angle
thru wedge shimming the mounting bolt between the 2, can be done.
Rowan,
I'm curious. Are you running a 9-speed or 10-speed? 6603's are designed for the latter.....
At the front, 9-speed and 10-speed components are pretty interchangeable from what I can determine. I'm running a 10-speed FD, 10-speed chain, and 9-speed MTB crank, for example. Rear-shifting is where you need everything to match.
Quoted: 3370 Post(s)
Liked 5,489 Times
I have an XT triple 22/32/48, with 10s 11-36. I just replaced an Ultegra triple FD with an IRD Alpina D. The problem is the Ultegra's cage is too long for a 48T chainring. You can't set it to the proper height over the large ring, because at that point the lower end of the cage crashes into the chainstay. When set high enough to avoid the chainstay the middle->large FD shift sucked.
Velocommuter Commando
Liked 5,489 Times
IRC makes the only FD that works with a 48 max front Chain wheel with Shimano STI shifters. I have Sora brifters shifting an Ultegra triple FD on my '07 Sirrus drop bar conversion. It works but I have to be cognizant of what gear I'm on the back cluster and the front shift to the 48 is a "double clutch" before it makes the shift.
Quoted: 910 Post(s)
Liked 288 Times
What front derailleur did you select?
I need to mix a Sram X7 10-speed triple with a 44, 32 & 22t chainring set with Shimano 10-speed 105 brifters.
I'm trying to decide between a Shimano 105 (FD-5703) front derailleur and the IRD Alpina for triple.
Michael
Michael
deleteme
Bikes: deleteme
Quoted: 50 Post(s)
Too much compact double kool-aid being spread around me-thinks.
Barrettscv
Bicycle Mechanics
17
12-07-11 01:58 PM
3373jones
10
05-29-11 12:19 AM
