installing recessed mounting brakes in my old road bike
not sure if this is the appropriate forum
i want to change my single pivot to dual pivot brakes, but I've read i will have a problem with the mountings.
I read a lot of things and options, but not sure which would fit my bike.
here are two picts of my bike
what do you think? drill? use a front brake in the rear?....
thanks!
thanks!
car guy, recovering
Bikes: Olympia Competizione & Special Piuma, Frejus track circa 1958, Dahon Helios, many others
That type of rear brake bridge usually has enough metal to safely enlarge the hole, but if I were you, I'd use a recessed front on the rear with an ordinary nut. You can sometimes use a recessed rear on the front if you can get a nut inside the steerer tube. The fork crown and the steerer tube give you enough material to anchor the brake without the bolt passing all the way through to the back of the fork. There is not always enough room to start or turn the nut, though.
Michael Shiffer
EuroMeccanicany.com
Michael Shiffer
EuroMeccanicany.com
