I think I need new tires...
Bikes: Trek 820, Giant Sundance DX
Just got a Trek 1000, the tires didn't look great but I foolishly ignored it..that lead to a replaced tube and the LBS telling me my tires are rotted...
Well the Trek is on ice and I am back to riding on my MTB until such time as I get new tires which will be next month...the roadbike has shown me that I hate riding the MTB (sigh).
Of the old tires I am seeing some loss of material on the sidewall and threads breaking through to be visible. The sidewall rubber itself is brittle and shows signs of crumbling away around the threads as they get exposed.
So it appears I am going to need new tires and I thought I would ask for the pearls of wisdom that I can only find here...and here is the point where I give you some data.
The bike is a Trek 1000 with 700cc wheels, made probably in the 90's.
The old tires are 700ccx23 of some odd make, they could be original for all I know.
I ride around country roads in my area around 100 miles a week, but hoping for more.
For the most part they are decently paved, but there is one road that is just oil chip and nasty. There are a few spots of gravel where some industrial areas have driveways, the gravel is avoidable for the most part, potholes are not common and easily avoidable. What may not be avoidable are the occasional train-tracks and a few areas where there may be a bump due to very poor road construction.
As for me I weigh just about 220 lbs.
My LBS doesn't have the brands I hear talked about but I suspect I can order them online. I have heard that Conti Gators are good and so are Conti 4 seasons? But really I haven't much of a clue here..
Advice and Opinions very welcome.
Conti gatorskins are a bit heavier but will have fewer flats. Conti 4000 are lighter. I like either and would check prices on probikekit.com. Also, I would get 700x25 or even 28 if it looks like they would fit. These would be wider and a bit more comfy.
Bikes: Workcycles FR8, 2016 Jamis Coda Comp, 2008 Surly Long Haul Trucker
Liked 6 Times
Why would you wait a month for tires? My suggestion would be to get something cheap (in price & not necessarily in quality) and save up for the more expensive ones in the future.
Buy something from bike tires direct or nashbar and be on your way.
Starting over
Bikes: 1990 Trek 1500; 2006 Gary Fisher Marlin; 2011 Cannondale Synapse Alloy 105; 2012 Catrike Trail
Quoted: 10 Post(s)
But that's just me. Or more accurately, me and exile.
You know, I figured I would get the 'Don't buy the cheap tires" response right off the bat. Fascinating...
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,245 Times
I ride with these in Texas 700 X 28's if your bike will take them that size.
https://www.rei.com/product/724618/se...2-001b2166becc
Fred "The Real Fred"
Starting over
Quoted: 10 Post(s)
I ride with these in Texas 700 X 28's if your bike take them that size.
After ditching that wheelset for high-pressure clinchers, I've only had one other consistent tire problem in all the brands I've tried over 30 years, and that was with one of the early kevlar-beaded folding clinchers. Their grip on the rims was poor enough that acceleration caused them to shift on the wheel, putting stress on the tube's valve stem. In short order (like twice around the block) the base of the stem developed a fissure and failed.
Every other tire I've used has been fine.
Gentlemen...
I picked up a pair of inexpensive (Schwable Lugano), but not the bottom of the barrel tires last night. I came home with no experience of putting on tires, only with the knowledge that I need to learn how to do this because tubes and tires are a consumable.
A youtube video got me started and a little webpage got me finished when I ran into a snag with tube bulge around the valve area.
New tires mounted, a short ride and they are still holding pressure this morning!
Thanks for all the input and support guys.
Cheap tires from decent brands like Schwalbe or Michellin will be heavier and slower than their up-line, but if anything they will last longer. And for a lot of us, the cost-benefit of spending $120 on a set is questionable.
