melting a seatpost?
aspiring dirtbag commuter
so i got a piece of aluminum seatpost thoroughly stuck in an older steel frame i just got to try and fix up for my ladyfriend. my big wrench wont budge it.... and it needs to come out!
i heard from someone that it might be possible to melt the aluminum post out by using some sort of chemical??? anyone heard of this madness? or anyother good tips for dislodging a stuck piece of a seatpost?
Chronic Tai Shan
Bikes: Pake Single Speed
If aluminum oxide (corrosion) is the cause of the "stuckness" you can use ammonia to dissolve it. Or you can always cut it out.
See this website for good ideas:
https://www.sheldonbrown.com/stuck-seatposts.html
ex frame builder
Liked 5 Times
I’ve never heard of melting aluminum with chemicals; you can melt it with heat as a last resort.
When you say you have a piece of seat post in the frame does this mean someone has cut it off and if so is there enough of it that you can hold in a vise? Sometimes you can heat the seat post by pouring boiling water over it. (Outside; not in your living room please.) Aluminum expands at a greater rate than steel so initially this will make it even tighter; however when it cools it contracts and this is sometimes enough to loosen it. Grip the seat post in a vise and twist the frame back and forth.
To melt out the aluminum you are going to destroy the paint and you really need someone who knows how to handle an oxy-acetylene torch. You need what is known as a rosebud tip that gives a very large flame that will heat a large area. The frame needs to be in a vise; upside down. Heat the whole seat tube and seat lug area with the torch moving constantly until the whole area is an even dark red hot. The aluminum will start to melt and drip out; tap the frame with a small hammer further along the seat tube where it is still cold to help shake out the melting aluminum. Do not allow the frame to get to an orange red heat or the brazing will melt. Also when you start heat the frame; do it slowly by holding the torch at some distance and then bring it closer as the frame heats up.
History, photos and tech articles on "Dave's Bike Blog." 'dave moulton' Registry including a Picture Gallery https://www.davemoultonregistry.com/
Bikes: 2011 Lynskey Sportive, 1988 Cannondale SM400
Quoted: 20 Post(s)
Try a good solvent. I removed a stuck seatpost for a friend by spraying the inside of the seat tube with PB Blaster. I sprayed it from inside the bb shell and let it sit overnight. A sharp twist with a pipe wrench with a 2 ft breaker pipe over its handle for extra torque popped it right out with no damage to the frame.
Quoted: 114 Post(s)
Liked 118 Times
Good luck and let us know what worked.
Quoted: 114 Post(s)
Liked 118 Times
Originally Posted by MudPie
Before going to destructive techniques, have you tried chemical penetrants like WD-40 or penetrating oils to "dissolve" the bond? Some of the claims on cans of this stuff are pretty bold...
"Aluminum seatposts frequently become stuck by corrosion also, and penetrating oil is almost useless against aluminum oxide. Fortunately, aluminum oxide can be dissolved like magic by using ammonia."
Klaatu barada nikto
One thing nobody mentioned is how to prevent this from happenning again. Make sure you grease a seatpost when you install it. Grease is (mostly) what will slow down or prevent corrosion in the first place. I know it sounds counterintuitive, but it IS the right thing to do.
i made it through most of the post with a hacksaw last night in about 45 minutes (my arm is noticably sore today)....
gonna go home and hack some more. someone just mentioned to me that there might be some solvent to melt the aluminum so i fugred i'd float that theory here.
might buy some ammonia too! just gotta remember when cleaning (if we have some left over) to never mix it and bleach together... i made that mistake once already.
Dont know about you, but I know about Dave Moulton, and for those who dont know, he is a PRO. (Couldnt get more capital letters, sorry Dave ) So, be sure you are atleast a Pro before using the torch on your frame. It will work as Dave suggest, but remember, it sounds easy but thats just because its Dave saying it. Its a bit like Rambo... "Dont try this at home"
Listen to me
I have had success with drilling a hole thorgh the middle of the seatpost inserting a drift and hitting the drift with a hammer (both axially and radially with regard to the post)
Klaatu barada nikto
Hey, anyone know what happens when you mix ammonia with grease ...... like the mixture you (could)end up with in your BB after pouring it down the seat tube for this??? I think if I were doing this I'd be taking a look at that when you finish with the seat post. Just a thought.
Klaatu barada nikto
Originally Posted by AndrewP
Ammonia wont stay in your BB because it should drain out of the hole in the bottom
Really, what I am most interested in is what happens to grease when exposed to ammonia. If I had some ammonia around, I'd go mix up a batch ;-) Sorry about this tangent to the thread.
Hey Cascade168, take a heap of rust and then cut down a coca-cola can in small squares and set it on fire... Back in the old days it was sometimes used to weld railway tracks, so use a LONG stick to ignite it cause it gets hot
Klaatu barada nikto
Older Than Dirt
Originally Posted by cascade168
I'll bet if you mixed in some magnesium filings with that ..... Now then you'd have something
You would have Thermite which is used to do field welds on railroad track.
Doc
