I'm getting a chance to spec a build, wanting to know if this would be stupid or good
Bikes: Had a Surly Cross Check - was totaled in recent accident. Sadly now just a Fuji Crosstown as a backup bike.
I'm starting with a 700c Long Haul trucker frame.
I want to have a wheelset built around velocity touring rims (chuker I believe) 36 spoke.
I want an IGH - for my budget the Shimano Alfine 8 or a Nexus 7 (I may lean toward the 7 for price)
Here is the part I'm wondering - what shifter do you use with the hub? Can you use some sort of 'bar end' or 'friction' style shifter.
Finally, on the front crank I'd like to run a compact double with a traditional front derailleur, so this would effectively give me 16 / 14 (depending on which hub I get) speeds, right? Would cross chaining be an issue? Also, are there issues with the Shimano Alfine on day to day commutes and pulling a slightly larger load (light touring / lots of loaded commute miles). I also live in a hilly area.
So tell me if my idea is stupid. The reason I'd love this hub is that I have to start stop often. The shifting while stopped would be great. Also, I understand that once the cables have stopped stretching, these things don't need alot of fiddling (which would be NICE). However given my hilly area, I'd like a something like a 46 / 30 up front.
Thanks for thoughts.
Quoted: 550 Post(s)
Liked 325 Times
https://www.google.com/products/catal...ed=0CFoQ8wIwAw
That's not really an improvement.
You'll need a chain tensioner like this
I have 24 traffic lights and 10 stop signs each direction on my commute. There's always enough warning to shift before stopping.
On my derailleur equipped bike I only need to adjust cable tension when replacing the inner cables every few years and the one time my front derailleur clamp wasn't tight enough and it slipped.
Quoted: 86 Post(s)
i've had a few years experience with a nexus 7 and found it to be a sound piece of equipment. i had a trigger shifter, and even though it worked flawlessly, was by all accounts one of the ugliest and cheapest looking things i've ever had on a bike since i was an adult. this was a while ago so things may have changed.
as noted there is plenty of time to downshift before stopping with a derailer equiped drivetrain, and i lived in a city (sacramento) with no other transportation other than my bike, but still found the ability shift while stopped to be extremely convenient. YMMV.
i'm a minimalist (some say simpleton...) so i wouldn't find the front derailer, cable, chain tensioner to be worth the bother, but many think otherwise... sounds workable though.
BTW that nexus 7 weighs a ton, but suppose you know that already.
Quoted: 2026 Post(s)
Liked 1,096 Times
There would be no "cross chaining" issue with a double, or even a triple, in front. You would not have the perfectly straight chainline IGH hubs are noted for in either chainring or just in the middle ring of a triple but the deviation won't be that much.
tsume
Bicycle Mechanics
4
02-24-12 12:03 PM
Cyclist7530898
Bicycle Mechanics
11
01-31-10 02:24 PM
