Friction shifter adjustment
Bike Nerd
Bikes: mid 80's Fuji Supreme (commuter), LeRun unicycle thingy Raleigh Centrurion
Having an odd problem with my old school fuji. It wont stay in the lower gears, it tends to shift up out of them back towards the middle of the cluster. I checked park tool and sheldon brown's sites but I'm not sure what I should be adjusting.
Quoted: 4722 Post(s)
Liked 3,036 Times
In the centre of the drum for the shift lever will be an adjustment screw. This screw adjusts the friction on the lever assembly and holds the lever assembly together. Tightening it should prevent the slippage, but will require some experimentation to obtain a setting that provides smooth lever movement and balances the rear derailleur's return spring.
Bikes: Peugeot Hybrid, Minelli Hybrid
This bolt usually had a ring or wings on the head so you could tighten it if necessary while riding along. Lubrication of the shift lever pivot could also cause unwanted shifts to the smaller cogs to happen.
Quoted: 19 Post(s)
Liked 7 Times
Sometimes the ring may switch from friction to indexing mode. Simpler levers use the ring just to tighten the lever.
Consider dismantling and cleaning the lever. Note the order and position of the various washers and DO NOT LUBE the friction washers.
Bike Nerd
Thanks guys, I will try tightening the shifter itself.
Bike Nerd
That worked like a charm. thanks for the help.
