Touring on Continental City Ride Tires
Hello BF:
I have what might be a silly question -- I had automatically assumed that my good-quality city tires would be just fine for touring on as well. I've had the Continental City Ride 700c x32 tires for about 4 months and probably 1,000 miles now and they are just great. Not a single puncture and I ride every day for work on city streets and did a century on them as well which included ~40 miles on the gravelly C&O canal towpath. Once as I was truing the wheel on a stand I found a piece of glass embedded in the tread that had not punctured the tube (have no idea how long it had been there).
There are many other expenses related to gearing up for touring, so am hoping not to replace these -- this might just be a case of me thinking I need some more "stuff" instead of just getting out there and riding. In any case, I am about 230lbs and plan to carry possibly 25-30lbs of gear on a tour?
Are true touring tires going to give any benefit in terms of strength while carrying a load? Or should I just hold on to my $$ and go with what I have -- these perfectly good tires?
Thanks for any information.
Bikes: Hollands Touring Bike, Schwinn mountain bike, folding bike, tandem and triple
I have been testing tires on a course near my house and have concluded that the Conti Sport Contact is the tire I am going to use in the future. It seems tough and durable and fast. Fast for me at my weight and age (250 lbs and 63 yrs) translates into range per day. I used to ride 55 + mi. on 700x37c Conti Top Touring 2000. The 700x37c Sport Contact seem to be faster and tougher and are more comfortable.
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
If they work? Ride 'em. FWIW one of my "tour" bikes is currently running Forte Gotham City (Performance Bikes house brand) tires. I use that one for occasional rough stuff. I have used Cheng Shin, Kenda, Conti's, Michelin, Schwalbe as well as some off brand stuff. All did what they were supposed to do at the time. My favorites over all have been Michelin and Schwalbe.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Thank you guys for responses. I'm just going to ride out with what I have.
Should have asked about my wheelset from the beginning as well -- forgive another silly question. I've got the Shimano WH-R500 wheelset that came with my bike. It has 24 rear/20 front spokes. Now, I've already had a problem with one of the front spokes coming loose and I ended up replacing it and using loctite on the new nipple. My question is this less than the number of spokes necessary for touring? I know that sturdy wheels are good to have -- the bike will be carrying a load of ~260 lbs rider+cargo. Once again, hoping not to replace what I have.
btw, my silly questions are reminding me of this blog post called "Some answers to just about any bike forum post I’ve ever read" -- I saw at the Surly Blog last month. It's pretty good, hope you get a kick out of it:
https://surlybikes.com/blog/2514/
Bikes: 1988 Giordana Capella | 1994 Cannondale T700 | 2007 Co-Motion Periscope
You haven't really provided enough information to answer. In all cases I'd prefer a higher spoke count. Having said that, if you're not departing civilization and on smooth roads you can just see what happens with your existing wheels. Worst case is you get a lift to the nearest bike shop. Best case is that you don't have to lay out money on new wheels. If you're going to be on rough roads in remote areas, I'd spring for the new wheels. You've taken the bike on the C&O which can be rough, adding 25 lbs of weight isn't going to make a huge difference to your wheels.
I wouldn't ride those wheels...but I am pretty old school and ride conventional 36/36 on most of my bikes. I actually have one that is 32/40
Aaron
Aaron
I wouldn't do it.
Consider Handspun production wheels or get PeterWhite to make the least expensive touring wheels.
Biketouringhobo
Touring
47
02-22-17 09:39 AM
Harhir
6
09-17-15 10:40 AM
Elantr025
General Cycling Discussion
7
04-15-12 07:55 AM
