Dealing with Toe/Wheel Overlap
Bikes: 1997 Specialized M2Pro
When at the 3 o'clock pedal position, my toe overlaps the front wheel. I've read that this is relatively common, but I see it as a real problem when turning around very slowly. For example, yesterday I rode up a steep hill a bit, and then turned around. I had to be very careful not to have my pedals in the wrong position.
Any tricks to dealing with this, or should I just practice these low speed turns?
Thanks,
Al
Thanks,
Al
The Fat Guy In The Back
Bikes: '81 Panasonic Sport, '02 Giant Boulder SE, '08 Felt S32, '10 Diamondback Insight RS, '10 Windsor Clockwork, '15 Kestrel Evoke 3.0, '19 Salsa Mukluk
Quoted: 320 Post(s)
Liked 177 Times
When you make a sharp turn, get in the habit of moving the inside pedal to the 12 o'clock position. This will eliminate the risk of pedal strikes or toe overlap.
Unless you're riding fixed gear.
Visit me at the Tundra Man Workshop
Time for a change.
Liked 5 Times
Have the same problem on Boreas and it is not a problem. Tyre hits foot and the foot pedals on and goes past the tyre. Just don't panic and straighten the bars.
Spike Milligan
Spike Milligan
Bikes: 2017 Colnago C-RS, 2012 Colnago Ace, 2010 Giant Cypress hybrid
Quoted: 408 Post(s)
Liked 122 Times
It's also a good idea on tight u-turns to unclip (if you are clipped in) so you don't lose control if you foot does hit the wheel during the turn.
HCFR Cycling Team
Ride Safe ... Ride Hard ... Ride Daily
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
just keep riding
Quoted: 173 Post(s)
Liked 33 Times
Be taller so you can ride a bigger bike.
Liked 6 Times
Practice the turns with the inside foot at the 12 o'clock position as Tunrda Man suggested. It become habit pretty quickly.
A conclusion is the place where you got tired of thinking. - S. Wright
Favorite rides in the stable: Indy Fab CJ Ti - Colnago MXL - S-Works Roubaix - Habanero Team Issue - Jamis Eclipse carbon/831
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
A surgeon or podiatrist could probably help downsize your feet.
Starting over
Bikes: 1990 Trek 1500; 2006 Gary Fisher Marlin; 2011 Cannondale Synapse Alloy 105; 2012 Catrike Trail
Quoted: 10 Post(s)
Probably too late in life to try binding.
Squeaky Wheel
After a while it just becomes second nature to position your pedals/feet properly when making sharp turns.
Is this really an issue for anybody? I have eight bikes, going back to my college Peugeot from the '70s, and five of them have overlap. In 40 years of riding, I've never touched the front wheel once.
It's not necessarily a frame size issue, by the way. My smallest frame is 62cm; the others are 64 or 65.
Quoted: 1856 Post(s)
Liked 664 Times
I find it can be a problem when I'm tired, and I'm preferring to ride my bikes that are long enough not to overlap.
When I was younger I never failed to put my foot at 12:00 and avoid overlap, but these days I don't always remember to do that.
Bikes: confidential infromation that I don't even share with my wife
Quoted: 35 Post(s)
My toes will hit the tire when making sharp turns on my cyclocross bike especially when noodling around in the back yard or woods on mtb trails. In races it also happens but I don't think it has ever caused a problem other than scuffing the shoes where the contact is made. Wearing sandals would not be advisable.
your god hates me
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Quoted: 1252 Post(s)
Liked 1,284 Times
Practice one-legged drills...then, when making tight turns, pedal with the inside foot half a revolution, then backpedal half a revolution. Lather, rinse, repeat. iow, keep your outside foot away from the front wheel until the turn is complete.
Bikes: Custom 650B tandem by Bob Brown, 650B tandem converted from Santana Arriva, Santana Noventa, Boulder Bicycle 700C, Gunnar Sport
Quoted: 23 Post(s)
I am short and like a good handling bike, so I have toe overlap on all my bikes. I made it a habit to put my heals down and toes up as far as possible when making low speed turns. Solves my problem.
The idea of unclipping is also a good one that I have used on our tandem from time to time. unclip and place pedal in arch of foot and pedal through the turn then clip in. Helps to get good at clipping in.
Not short by any means. 6'1" and I definitely have this problem. Caught my self bad the first time out and really since then have had no issues. Guess I just compensated. Yup, pedal all the way up on the side you are turning toward.
Liked 6 Times
You know, as I think about this, I remember being asked by the folks at Independent Fabrication if toe/wheel overlap was something I absolutely didn't want when they built my bike. (I told them all my other bikes had it; so not to worry about it.) I'm guessing really good frame builders can figure out more than one way to get the desired ride characteristics.
Ride like the wind!
Bikes: Trek 700 wsd
My Trek owners manual had a big warning about this very thing.
(Yes, I rtfm. Ima geek.)
Thanks, I'll practice with the correct procedure until it becomes second nature.
I never even realized this was a problem until turning around on the street one day. The wheel was turned to the left, then my pedal got into the 3 o'clock position, and when I went to straighten out the wheel it hit the foot, and stopped. The handlebar torqued out of position, and I fell, but not all the way down.
Time for a change.
Liked 5 Times
I would put it down to a senior moment rather than a problem. Or I would if I could get back on the chair after falling off laughing.
Spike Milligan
Spike Milligan
+ with the out side pedal, in relation to the apex of the corner, down, you shift your weight
to that foot, and your C of G moves down a ways.
Erect member since 1953
Bikes: Trek 520 Grando, Roubaix Expert, Motobecane Ti Century Elite turned commuter, Some old French thing gone fixie
Quoted: 121 Post(s)
Liked 38 Times
Just don't go slow. Ever. Problem solved.
Quoted: 966 Post(s)
Liked 1,629 Times
If you are using cages go to a smaller size - Could also go to 170mm crank - Can it be a problem - YES - I have had two falls when turning on my UNIVEGA - I am OK now but it took some time to get used to turning...
Century bound
Bikes: Felt AR4 and Cannondale hybrid
I'm glad you brought it up as I have had similar issues and wondered if I were the only clumsy cyclist out there.
Quoted: 659 Post(s)
Liked 595 Times
My Trek 460 has serious overlap but it's not been a problem.
Do touring bikes with the longer wheelbase have overlap?
