Fundamental skills for the winter cyclist
coitus non circum.
1) The farmer blow
2) Riding over a patch of ice
In my experience, one simply cannot ride effectively in the winter until these skills are mastered. If I even LOOK at my bike in the winter, my nose becomes a raging torrent. And, the super slick frozen puddle or man hole cover is another formidable challenge. So, for anyone how is interested, here is how I do them.
Farmer blow
a) Look to see if anyone is watching
b) Blow the left nostril over the left shoulder and right over the right
c) Cover the non-blowing nostril (use the same hand as the nostril being covered ie covering rt nostril, use rt hand)
d) simultaneously sharply expel air through the unvoered nostril while flipping your head up and back so the resulting rockets flies back over your shoulder.
e) If so inclined, and if you have the bike handling skills, admire the arcs, parabelas, and distances of the resulting product.
f) If someone WAS watching, pop a wheelie and shout something existential.
Riding over ice
a) what ever you do, DON"T turn on ice
b) stop pedaling
c) glide over the ice holding as still as possible
d) Think centered thoughts
e) If you DO have to turn, don't use your handlebars, turn by leanign your bike
f) try not to brake, but if you do, only use the rear brake. Front brake on the ice, you're going down, baby.
Anyone else have some fundamental winter biking skills to share?
ps. what to say to auto driving colleagues as you leave the office during a winter storm, "Be careful out there, cager, those things are dangerous! Hey, where's your helmet?"
Farmer blow
Riding over ice
b) stop pedaling
succumbs to errata
Woah.. over the shoulder farmer blows? I've found it much more effective to blow downward, under my arm. The downward aim also helps facilitate the expulsion of snot, and when done correctly, the process is usually fairly well concealed from casual on-lookers.
無くなった
Bikes: I built the Bianchi track bike back up today.
Originally Posted by Mars
1) The farmer blow
b) stop pedaling
coitus non circum.
HereNT,
Do you feel that you have better control over your fixie on the snow/ice than you would with a freewheeled bike? If so (which I'm guessing, why?)
Perineal Pressurized
Originally Posted by HereNT
Sorry, will never be able to do that one. I'm a fan of the 'sniff it up then down your throat and hawk a massive loogey, preferably right at someone watching' method. It might have to do
Wheres the beef?
Bikes: Zebrakenko fixie, cannondale mountan bike schwinn continental and twinn tandem all SS
i have not rode my fixie on ice yet (mpls has been tame so far) however it would seem that while stopping i would know quickly if the back wheel started slipping and could let up on the back pressure..
and hope to stop before hitting whatever made me want to stop
hehe
Formerly Known as Newbie
You forgot the number one: get a pair of decent studded tyres. And I too find leaning on curves hazardous, even with said tyres. If you have to make a controlled turn on slick ice, methinks the best way is to slow down to the point where you can turn without leaning much at all. And you need to brake before you turn, even studded tyres have a tendency to slip if you brake aggressively while turning.
Snow OTOH is a different matter entirely. You will be able to lean etc. (unless there's ice beneath the layer of snow).
--J
--J
To err is human. To moo is bovine.
Who is this General Failure anyway, and why is he reading my drive?
Become a Registered Member in Bike Forums
Community guidelines
無くなった
HereNT,
coitus non circum.
Regarding a winter lean turn. Keeping your weight vertical, lean your bike slightly underneath you. You will find the bike does a slow even turn. You can apply the same concept on super slick ice. The keys are the continuing centralization of weight above the bike and a slight lean while keeping the bars straight.
Hope this helps.
Hope this helps.
coitus non circum.
HereNT,
I ride a fixie about once a week to augment my other riding. They are awesome bikes. Another question, though, have you riddne much in snow with your fixie? I'm just imagining trying to power through the deeper stuff.....
Year-round cyclist
Riding over ice
b) stop pedaling
Riding over ice
b) stop pedaling
As for braking, the best on-ice braking is to apply both brakes smoothly and evenly so that you don't lock any wheel.
無くなった
HereNT,
contre nous de la tyranie
Bikes: Trek 830, Trek 520, Surly 1x1 fixed
I think that one of the most useful skills is quick frozen rut scouting. If you are navigating through tall frozen walls of ice, that criss-cross, and sometimes abruptly end, you have to keep your wits about you, to follow that one path through the maze, without having to stop, or block the flow of traffic.
The 'net ruined cycling
Bikes: Steelman Eurocross, Peugeot U08 fixie, Specialized Expidition, Raleigh Sprite 27, Serotta CDA
I'd say the most fundamental skill is falling. If you ride bikes, you'll fall, and if you ride in winter, you'll fall more. Get used to it. I'd say second is preparation; you need to dress very accurately for the weather or you'll overheat or freeze, you need speciality gear to deal with sub-zero conditions (anyone found a good anti-icing compound for goggles yet? I mean anti-icing, not anti-fogging, I get frozen ice on the inside and outside of goggles when it's below -10F. I've tried to stop breathing, but it hasn't worked so far.), and it's best to keep your machine in excellent mechanical condition because I'm sure changing a flat at -10F is even less fun than at 30F.
coitus non circum.
I here you ajkloss42!!
After one -20 ride to work, a coworker asked if the silver things were the bottom of my sunglasses were some kind of clips. I looked. They were icicles from tears.
無くなった
I've had a 2 inch icycle from tears on glasses before. I was wondering why my cheek was colder in that spot than the rest of my face... Found out when I got off the bike.
Good times.
Good times.
Wheres the beef?
drives me crazy when my eyelashes freeze together
maybe its time to get some goggles
totally louche
Bikes: the ever shifting stable loaded with comfortable road bikes and city and winter bikes
Liked 9 Times
I found the reverse layout skid turn to be invaluable in all my years of winter cycling. Get good at it and your foot never touches the road. Slow and elegant show of grace on snow and ice.
Unfit, fat and forty
Bikes: 2 cheapo ghetto ones (hey Sweden is expensive...)
totally louche
Liked 9 Times
A reverse layout skid turn is where you hit the rear brake, throw your back wheel out and turn your wheel in the opposite direction of how you want to turn, and lay it out, with your foot off the inside pedal for balance. Whe you get good at it, you rarely have to touch the ground with your inside foot. It works like a champ for changing direction on snow and ice, and a lot more solid than trying to ***** foot your way through one. I don't agree with Mars' technique for turning on ice. I guess its just a skidded turn, but couldn't think of how to describe it.
I guess I'd describe that as floating the rear wheel during the turn with countersteer. I do essentially the same thing (less hanging a foot out) in my Mustang pretty much every time I drive, but I use throttle not brake to break the rear end free. It's a reckless, irresponsible, unnecessarily complex, very fast way to turn. I like it a lot. I shall try it in the snow on the bike at the next opportunity.
If you start doing doghnuts on your bike, alert me; I want to watch!
My nose output is more like water then anything else so that farmer thing wouldn't work for me. What I do is put a papertowel in my coat pocket and use that to absorb the drip with a free hand. The paper towel (or alternatively a shop rag) is thick & stiff enough to be handled with winter gloves. Another option is a cloth hanky which is also reusable.
One technique I use for sudden stops is to simply jump off my bike seat and break with my shoes/boots as well. I've used it in the summer when I'm tearing along not bothering to break for a intersection but suddenly notice a incoming car. But its especially useful in the winter when breaking is so much more difficult. It takes some practice to do this maneuver without groin injury though, well depending on your bike design.
Also sometimes the pedals continue spining and hit you on the back of the leg which can cause some injury depending on what kind of grip they have. My pedals have high grip and can cause quite some injury if i'm not careful.(little bloody holes alongside my leg) Of course the idea is to stop the pedals from moving first but this is a emergency break proceeder plus sometimes you accidentally hit the pedal when jumping down causing them to spin around.
