loose brake handles on dropbar
Old 11-20-04 | 08:04 PM
18 dog baby
Bikes: 2008 crosscheck complete, 1984 Pugeot fixed conversion
Don't know what they're called, but the bit that holds the brake onto the dropbars on my panasonic is super loose. How do I tighten them?
Any special tools involved.
If so, can I just zip tie then?
Thanks for the help
2mtr is offline
Reply
Old 11-20-04 | 09:04 PM
DieselDan's Avatar
20 Anniversary
From: Beaufort, South Carolina, USA and surrounding islands.
Bikes: Cannondale R500, Motobecane Messenger
There should be a Phillps head or hex head bolt under the brake lever that needs to be tightened.
DieselDan is offline
Reply
Old 11-20-04 | 09:31 PM
WorldWind's Avatar
Hardtail
Bikes: Richey Everest, Supercomp, Richey custom handbuilt Road, and others.
Loosen the break arms at the wheel to put slack in the cable, and then pull the break lever all the way to the bar. In the opening between the hood and the top of the lever you should see the head of a fastener. Tighten that, until the hood is secure on the bar.
WorldWind is offline
Reply
Old 11-20-04 | 09:37 PM
18 dog baby
Thanks all. Once again this place rocks.
2mtr is offline
Reply
Old 11-21-04 | 03:06 AM
Year-round cyclist
20 Anniversary
All ok, except the brake levers I have use either a 4 mm or a 5 mm Allen bolt.
With one set of levers (non aero), I have to remove the cables to tighten the bolt.With the two others, I simply depress the lever and wiggle the Allen key through.
Michel Gagnon is offline
Reply
Old 11-21-04 | 04:58 AM
cascade168's Avatar
Klaatu barada nikto
I have some DiaComp brakes that use a slotted screw
cascade168 is offline
Reply
Old 11-21-04 | 07:39 AM
DieselDan's Avatar
20 Anniversary
Hex head is an Allen head.
Reply
Old 11-21-04 | 03:44 PM
WorldWind's Avatar
Hardtail
Yes well thats why I said "head of a fastener" OK who else has a strange bolt on ther bike?
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
