giant expressin
giant expressin
Hi all , I am a new poster this forum , and a novice mechanic. I have a Giant expression which I use for commuting, the bottom bracket appears to be loose.
From the little info I have managed to gain it is of the 'semi cartridge type'.
My question is can this be tightened up and which spanner would I need to buy to do this?- I already have a crank puller but no c type spanners- are these standard or different?
Also if it is not possible to tighten it which replacement cheapish part would be the best replacement and the correct size?
many thanks, Rob
many thanks, Rob
ellenman
Road Cycling
24
12-31-11 09:42 PM
