Chuckanut Century 200K route
I am planning on doing the 200K route for the Chuckanut Century on September 18th, but I can't make any sense of their maps.
https://www.chuckanutcentury.org/
https://www.chuckanutcentury.org/ChuckCenturyNorth.pdf
https://www.chuckanutcentury.org/ChuckCenturySouth.pdf
I see a ton of different loops, but no clear 124mi or 100mi route. Has anyone here done this ride and know what loop is the 200K? I want to bikeroutetoaster up the route so I can see the elevation profile.
Thanks
Thanks
Squeaky Wheel
If you do the 50 twice it's 100. If you do the 62 twice, it's 124. I've never done this ride, but I suspect that most combine the south loop with one of the north loops.
don't try this at home.
Quoted: 973 Post(s)
Liked 511 Times
You probably do both the north loop 62 miles and the south loop 66 miles.
I see they have spray painted markers for the routes. Good.
Thanks for the comments, I went ahead and bikeroutetoaster'd a the North 62 and South 66 if anyone is interested. Doesn't look like that much elevation gain total.
https://bikeroutetoaster.com/Course.aspx?course=300571
https://bikeroutetoaster.com/Course.aspx?course=300584
convert
Bikes: 1994 Bridgestone XO-4, 2006 Trek 1500
Having done the 200k, I'll confirm that you do the biggest loops both north and south. When, I did it, a lot of roads were painted for the MS ride, so make sure you know the route or what symbols Chuckanut Century is using so you don't follow the wrong route. Have fun!
