High (low?) limit screw too short?
Bikes: (shortlist) Cyclops, Marinoni, Mariposa, Air Firday, Pocket Rocket Pro, NWT, SLX Fuso, Claude Pottie (France) x3, Masi Team 3v, Lemond Zurich, Bianchi OS
Quoted: 158 Post(s)
Liked 33 Times
Low limit screw too short?
I am having a bit of trouble getting this Chorus RD tuned.
it is just touching the spokes on the largest rear sprocket and I would like to back it off a bit.
But the limit screw, fully screwed in, doesn't engage with the stop bit.
what am I doing wrong?
I can't believe that I need a longer limit screw.
suggestions?
Peter
suggestions?
Peter
Low car diet
Bikes: 2006 Windsor Dover w/105, 2007 GT Avalanche w/XT, 1995 Trek 820 setup for touring, 201? Yeah single-speed folder, 199? Huffy tandem.
If you're trying to limit how far the derailleur can travel toward the spokes, then you adjust the Low (L) limit screw, since you're trying to position it under the low (largest) gear. So, make sure you're adjusting the correct screw. Is the other screw touching the derailleur body when in the largest gear?
Liked 7 Times
Also confirm that the chain is on the smallest chainring and largest cassette cog when adjusting the low limit screw.
Quoted: 158 Post(s)
Liked 33 Times
thanks
But that is the Low LImit screw shown in the photo. screwed in all the way, it still doesn't catch the flang bit there.
Now, I notice that these High and Low Limit screws actually have springs on them, between the screw head and the derailleur body. when the screw is in as far as it can go, this spring is compressed and takes up enough space that the screw doesn't reach the flange.
if I remove that spring, I can get enough travel on the screw to hit the flange and keep the derailleur out of the spokes.
should I have to remove the Low Limit Screw spring?
Low car diet
Not personally familiar with Campy RDs so can't comment on that.
Look at the RD cage from behind. Does it look straight up and down, parallel to the frame/wheel? If it's bent in, that could explain why the L screw isn't doing anything. The RD hanger (or less likely the derailleur itself) may be bent in.
Liked 7 Times
It's hard to tell what is going on from the picture. If the bike is upside down turn it right side up and take a few more pictures, especially one from the rear. I was also wondering if the derailleur or derailleur hanger could be bent.
Looks like u have more turns in the screw, IMO. Always what u can do is to put a spacer between the wheel and the cassette to move it out a few mm. Is that a 9 speed setup?
Bikes: '02 Lemond Buenos Aires, '98 Fuji Touring w/ Shimano Nexus premium, '06 Jamis Nova 853 cross frame set up as commuter, '03 Fuji Roubaix Pro 853 back up training bike
suggestions?
Peter
suggestions?
Peter
don't try this at home.
Quoted: 973 Post(s)
Liked 511 Times
How many cogs do you have? Are you on the largest cog (of 5?) in the photo?
Yes, that is the correct limit screw, and it's already extended far more than is typical. If your cog set is only 5 speed, is it narrower than what the derailleur was designed for?
More pics, please. A view from the back of the bike, and a side view, etc.
Bikes: 2007 Nagasawa with C-Record, 1992 Duell with Croce D'aune/Chorus, three Gazelles, M5 recumbent
Quoted: 47 Post(s)
Liked 25 Times
That is an older Chorus RD. In the early 90s, they came with an extra longer screw in the box for 7 speed freewheels. So it is possible that ypu need a longer screw.
Quoted: 158 Post(s)
Liked 33 Times
more pics
and it currently has an 8 speed wheel
Quoted: 158 Post(s)
Liked 33 Times
Triggerhappy007
Bicycle Mechanics
12
11-09-15 12:24 AM
cajunpedaler
Bicycle Mechanics
11
12-01-14 06:09 PM
skydive69
Bicycle Mechanics
4
07-17-10 10:02 AM
