The dreaded creak-itis
The Weird Beard
I have skimmed the previous creaky threads in here, so this is more of a vent than anything else. I of course welcome advice on anything I may have missed.
Rode home in a bit of a rainstorm last week. This, after I had spent the previous weekend cleaning my BB shell and cups, lightly greasing the shell and threading the cups with teflon tape. Removed and cleaned the RD, hanger, and seatpost as well. All that's left are pedals and then possibly *gulp* the frame. Since the symptoms cropped up after the rain, but having just rebuilt the BB, I am thinking it's not the BB. I even removed and re-installed the FD just to be sure.
Guess it could be the chainrings, but hoping for the best. Only happens under load, but it doesn't take much to get to Creaksville.
105 Hollowtech II BB
Alu frame
Sora compact (50/34) crank
Sora RD
105 5600 FD (I know, on a 9 speed - I am not rubbing though)
Crank Bros. Candy-1 pedals
Forte Titan wheelset (a month old)
Alu frame
Sora RD
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
Also check your bikeshoes/cleats if you wear them. Plastic on plastic rubbing/flexing caused creaking in bike shoes are not that uncommon.
Chombi
Chombi
The Weird Beard
Saddle is a good idea, although the creak seems to be coming from the lower end of the bike and occurs while standing. Will re-install to be sure.
Yup
Location: where the sunbeams end and the starlight begins
Bikes: Kona Unit, planet X cx bike, khs fixed gear
Quoted: 9 Post(s)
Liked 6 Times
I had a horrible creak on my cross bike, only happened when cranking hard on hills. Tried everything, new b/b, regreased shell, greased seat post, saddle rails, different pedals, changed crank, changed b/b and crank type from Isis to square taper. Drove me nuts. Turns out it was from the stem. Added a touch of grease to faceplate bolts and stem bolts, on headtube and on inside of faceplate. Solved the issue.
When sadness fills my days
It's time to turn away
And then tomorrow's dreams
Become reality to me
Bikes: (2) 1994 Cannondale R900, red, Silver Trek hybrid
Quoted: 69 Post(s)
I have had a problem with a creak that would go on if I peddle or not and on two different rear wheels. Mine was the rear spokes. If you oil them right where they meet the hub its quiet till you need to do it again. And it makes the wheel look terrible
The Weird Beard
What a dork I am. Turned out I did not tighten down the non-drive crank arm well enough. It was tight, but you know, not tight enough.
Dork.
Let this be a lesson to you, and by you I mean me: Always check your work!
Dork.
Constant tinkerer
Good thing you caught this early enough. I learned the hard way once on an LX crankset. I use a torque wrench now...
I checked all the usual items...twice. Turned out it was the headset bearings creaking...yet it sounded and acted like a bottom bracket problem
Subjectively Insane
Bikes: '09 Rodriguez Adventurer Custom, '08 Trek 7.3Fx
My most recent creaking wound up being the ferrules creaking inside the cable stops, don't ask me how much work I put into re-greasing things before figuring it out.
I had a similar issue a couple weeks back. Drive side crank arm slowly worked loose on my commuter. Started squeeking on downstroke. The bolt had worked loose over time riding on cobblestones. Regreased, installed and torqued them up - last time I did it was a guestimate as I loaned my torque wrench out to a buddy. Not this time!
The Weird Beard
I do not own a torque wrench, but I'm pretty good at gauging tightness. This was my first oversight in quite a while, and with the severity of injury it could have caused, learned from it. Think I'll start saving for the torquie though...
JustinNY
Road Cycling
7
05-01-12 09:15 AM
