Bike lock help
Bike lock help
I recently got Mini Cable Lock from WordLock and was wondering if this thing is secure. Do you think it would be easy to break off? Is it secure?
-48 inches long x 0.25 inches thick (1219mm x 6mm)
I don't live in a big city or anything, so I am not that worried but I would like something that won't just snap off.
LINK!
LINK!
Bikes: 2012 Surly LHT, 1995 GT Outpost Trail
Don't know anything about that one specifically, but I should note that all cable locks are susceptible to bolt cutters, so I carry a U-lock (which are susceptible to angle grinders, but those are more rare so... choose your level of comfort I guess)
Bikes: Schwinn Tourist (2010), Trek 6000 (1999)
Those cables look like they're about 1/8". They are easily defeated with a pair of diagonal cutters. Even many 1/4" cables can be easily cut with a quality pair of diagonals or tin snips. In about 5 seconds.
They could work for a low-risk area, or as a secondary (ie, locking front wheel to frame, with u-lock securing frame to rack).
---EDIT---
Saw the cable dimensions. Would not use it it lock up overnight, or for more than an hour or so in a public place (Assuming low-risk area); or as a secondary lock.
More or less, to keep "Honest people honest".
---EDIT---
Bikes: DHS Jumper BMX; RichBike MTB
Combination locks are generally less secure than key locks. A thief could figure out the combo, plus that when you remove the lock you must be sure that nobody can see the combination. Furthermore an unprotected cable can be easily defeated with bolt cutters. The conclusion: simple cable combination locks are the least secure bike locks. The best way to secure a bicycle is to use a flat-key U-lock. Or, if you want something portable, you can use an armoured(steel-jacketed) cable, like I do. Armoured cables are not typically susceptible to bolt cutters.
It is a weak lock. You may be in an area where cable locks, though ALL can be easily cut, are enough to prevent your bike from being stolen, but this is still a weak lock, even by cable standards.
Bikes: Raleigh Grand Prix, Giant Innova, Nishiki Sebring, Trek 7.5FX
Since you don't live in a large city, you're most probably alright.
If you lived in NYC, Detriot, Chicago, Miami, or Oakland you should've just saved your lock money to go towards another bike. It's a really crappy lock!
A thick chain and a Master Key Lock would serve you much better anywhere...
PS.
Bike thieves hate ugly seats! If you have an ordinary bike with just ok components, they'll look over your bike if it has a really missed up seat, or no seat at all!
PS.
Quoted: 4234 Post(s)
Liked 2,949 Times
I'd say it's fine to lock your wheels to your frame while you use a U-lock to lock your frame to something secure. Might not prevent all thieves, but a thief that sees you have two different locks might move on to a different bike that just has one (or none).
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
But make sure the new U-lock is not vulnerable to picking. Many tubular pin tumbler locks can be opened with the barrel of a cheap pen, so make sure to avoid these models.
yea lock the rear wheel thru the rear triangle to a tall pole, or bikerack,
and the cable lock around the front wheel , to the frame or the U lock to keep 2 wheels on it,
for brief daytime stops.
