Bottom Bracket Issues
Hi
I've recently bought an old racing bike (probably mid 80s)
Im doing it up and have have removed to original bottom bracket, which wasn't a sealed unit.
Im buying a new bottom bracket but i'm not sure what axel width to get. The axel on the original bike was 150mm long. Would a new Shimano UN26 or UN54 with a 113mm axel be ok? Or would i need one as long as the original?
Thanks
J
Thanks
J
Quoted: 2026 Post(s)
Liked 1,095 Times
If the spindle has threaded stubs sticking out of each end and the cranks are held by nuts, then reptilezs is correct. Ignore the threaded stubs and measure from the ends of the square tapers.
Old fart
Quoted: 3571 Post(s)
Liked 3,367 Times
Dimensions A, B, C, and D should match those of the original spindle as closely as possible.
Liked 1,095 Times
prestoPress
Bicycle Mechanics
12
05-30-18 10:02 AM
